What Size Drill bit?
Been super busy lately but finally getting a few hrs to work on the still upgrades, adding a thumper. Can someone tell me the OD of 1/2" type m, or the size drill bit I should use for a snug fit? I've got a piece of 1/8" copper plate, and some 1/3" tubing, trying to make my own ferrule for the inlet/outlet for thumper.
Swedish Pride wrote:
Re: What Size Drill bit?
The OD of 1/2" type M is 5/8". I use a 5/8" bit in a press with oil for a snug fit. If you are using a hand rig, be sure to keep it held solid and steady to keep things snug.
Thanks for the tip! I'm using a cordless drill, so maybe I'll get a 7/16" drill bit and see what happens
7/16 seems a bit small just pre tap the spot your drilling and hold the pipe in a vise.
Agree with bushman, Use the correct size bit. Just use a center punch to set your spot, hold in a vice, and hold the drill motor steady. It should be tight with the 5/8, and solder will fill any minor gaps.
If you drill a 7/16 hole you'll just make a messsy out-of-round hole when you then try to drill a second, slightly bigger hole, that is the correct size. (Experience speaking
- jedneck
Step bit and stop just shy of going through with the step you need. Then flare the burr out to get tight fit.
big help
Dunder
big help
Dunder
+1. Excellent advice.jedneck wrote:Step bit and stop just shy of going through with the step you need. Then flare the burr out to get tight fit.
+1 a 2 flute drill bit will not make a round hole in thin material even with a drill press,still_stirrin wrote:+1. Excellent advice.jedneck wrote:Step bit and stop just shy of going through with the step you need. Then flare the burr out to get tight fit.
that's why I use reamers.
Appropriately sized stepper-drill ?
They always make nice round holes unlike the 2-flutes drill-bits that can end up making trefoil shaped holes in thin material.
Also, other thing that can help is to flare out/in an undersized hole a little and open it up ever so slightly with a drift or flaring tool to get a tolerance fit. (Makes for good soldered joints).
This! Worked like a charm and held the tubes in place snugly for test fitting and soldering. All charged up for a vinegar run/leak test tomorrow!jedneck wrote:Step bit and stop just shy of going through with the step you need. Then flare the burr out to get tight fit.
http://homedistiller.org/forum/viewtopi ... =2&t=21258 just another solution for joining small tube to large.
thanks to Zapata for finding this link.
+1 and if you drill the hole too big, A copper hole can be made smaller with hammer.
- Truckinbutch
Learning to be a tinsmith is another interesting aspect of this hobby . DIY distilling opens a craftsman to so many levels of skills in several venues .
