Just Post a Pick of your Rig
- Nokum Stiff
Re: Just Post a Pick of your Rig
15.5 gal SS half barrel keg boiler, 7.75 gal SS slim quarter keg thumper, 30 gal food grade barrel flake stand with 20' of 5/8" type L copper tubing.
---Stiff
---Stiff
**Voluntary reading..MANDATORY, Voluntary reading!**
Cranky's Spoon Feeding For NewStillers!
Cleaning Your Still
Glossary of HD Terms
Safety and Related Issues
quando omni flunkus moritati
Cleaning Your Still
Here ya go.
Sent from my SM-G900V using Tapatalk
First column pot still. Now looking for large diameter copper pipe for a reflux column.
My first build ,!,SCR for 5500watt , 4500w used to heat quickly,then unplugged !!
My 26 Gal. Reflux Still and my 22 Gallon mash mixer, and also my 13 Gal. Pot Still w/8 Gal. Thumper.
My rig, column, 2" copper with about 30" of packing. I have been making whiskey, so a low reflux kinda short column works for me.
Everyone has to believe in something. Me? I believe I'll have another drink......
Brewhaus Model PSII Reflux (CM), 8 gallon.
Stainless, packed with copper. Added natural cork topper & column insulation.
Plain & store bought. Not as fancy as some of yours, for sure! So I posted her on a blue matte to be different.
But she makes a fine neutral and is convertible to a pot still.
Has produced whiskey, Birdwatcher's, and Honey Bear. Excelsior!
- Just 4 Fun
nothing fancy but it werx
Just because it's called a liver doesn't mean it lives forever.
- ShineonCrazyDiamond
Shine on you crazy diamond."
My huffy puffy 2" pot. Currently changing the thumper to be all 2" like Usge's
- bluefish_dist
new vodka still. A little larger and taller. 7.5 ft of packed over 1 plate, 4" with 8000w.
Formerly
Dsp-CO-20051
Dsp-CO-20051
Ellie the Stripper:
- Attachments
- EllietheSTRIPPER.JPG (21.22 KiB) Viewed 4390 times
This is a setup I used for a workshop at Auckland Botanical Gardens. We distilled conifers of different types to compare yeild, aroma notes. Used the Alquitar to make a traditional type Attar - Honeysuckle onto Sandalwood EO.
Making Gin in a little Alquitar. 2 Litres of grain spirit in 40 % abv, 1 litre out at 80% abv - nice to dilute back to 45% to keep the aromatics bright.
15 gallon keg converted into a boiler and an 8 gallon keg converted into a thumper.
Finally, I got my 2" rig
Column 500mm
Mini column 150mm
Deflegmator 150mm Condenser 400mm And one part to collect heads with mini condenser water chilling system with easy connectors
Column 500mm
Mini column 150mm
2" reflux & 2" pot
The photos are reversed. CM Reflux on the top, Pot mode on the bottom.
Pot- 8 G SS Boiler, 1500w Still Heater element on controller, 1650w Element, 2" X 20" with one Copper Plug, 45 degree w/ thermowell n dig therm, 2" 90, 24.5"X2" Shotgun Condenser w/ 7X3/8" vapor tubes, 2"X3/4" endcap reducer
Reflux- 36"X2" packed w/ copper mesh, Sight glass, 6"X2" Dephlegmator w/ 3X1/2" vapor tubes. Everything from the pot still mode, push connect fittings. 30g Trashcan Reservoir, with two seperate pumps, so cooling is run straight in and out on each condenser. Needle valve on outlet of the Dephlegmator.
nothing too fancy, but i'm happy with it. Handles the full 3125W for stripping, at pretty fast speed. Only done one reflux run, but pulled 90% so pretty happy. If i add the 20"X2" packed i think i could hit 95%. But doing that requires me to get on a ladder and to collect on a table on a countertop. And i can't see the sightglass from the ground.
- VLAGAVULVIN
OK, my humble craft tools in a bit better light...
It has no vertical section and a steam pipe is very thin. So, it's useful for stripping runs only.
That small thumper-looking thing (between pot and chiller) is a bad "thumper" in fact. Some "samogon drunkoholic adepts" place their herbs or drop charcoal inside... but in my religion it's always empty. Its only sense is to prevent wort runaway into low wines on foaming.
Well, here we have sorta all-stainless LM boka. The scrubbles section (filled with copper or inox) is about 85cm and it's quite OK for fractioning of the vodka-like neutral alco. But at 350-400ml per hour at best, as its internal d is 22..23mm only. Dimrot coil is stainless, too. But its heat exchange is well coordinated with a max.possible heat. In theory I could get spirits as steam from the thermometer's hole but I never cared of it. What I do care about is a "dry pipe selection" of malty or fruity things when reflux is nil and heat is lower than average. Dry scrubbles do it not bad with the first half of the hearts.
P.S. Induction heating(almost stepless adjustment) / the heat it stable and nothing burns to the bottom...
har druckit för mycket
Here is a couple of the ones I have made.
New pot with thumper. Already did cleaning and sacrifice run
- BlackStrap
The one who cuts the firewood gets twice the warmth
Thank you for the comments.
Well... if the steam path is not trough thumper, then thumper is filled with watter...to the middle of the glass.
Then condensation is reduced to min. almost no condensation. Buti if it is some condensation, it goes back trough siphon.
Other option is...empty thumper and steam path trough thumper( then thumper has no function), but the temperature will be same as steam temp..and no condensation.
and generally steam flow is controledd by running water( white valve close to blue arow).
realised that might be some confussion at shematic drawing.
so I made some correction to make more clear how "siphon" is builded
