I have been doing a bit of experimenting and have come to the conlusion that copper phosphorous brazing rods are great for parts of the still that are not going to get really hot. Condensers etc as they dont need flux and are easy to use.
Am wondering about the pot builds though. I currently use mostly 56% Silver solder (Cadmium free) with a melting range of 620 - 650 degrees centigrade. I use some 49% Silver solder with a higher temp range for 2 stage solder operations.
There is no doubt that these give good strong joints on both copper and stainless steel, but for all copper builds are they over the top? I would not like to use soft solder on a boiler, but is there a lower temperature option than the 600 degree Silver solders?
I am currently building a tapered lyne arm from a 2" 1.2mm wall thickness, copper tube and am having real trouble getting the 3' length up to soldering temperature. For the silver solder that I am using, the joint has to be at the red hot stage to melt the solder.
I am currently improvising a forge to heat the entire length of pipe, to the point where my MAP torch can provide enough extra heat to get the joint up to temperature.
I have been thinking of using 0.9mm copper sheet to build a double boiler variation of a Pint style pot, and that will pose the same problem.
For those of you that have already done an all copper build, what sort of solder do you use? Are you using hard solder or are you using something in between, with a lower melting point, but higher than tin based soft solder? Or are you in fact using soft solder? Please coment.
