Please do let us know hoe it turns out
I use a propane gas burner under all my stills ....LOL ...except the LM/VM 2" .I'm a scaredy cat and don't like flames near high ABV alc .Pikey wrote: I wonder if any of our members with propane apparatus would like to comment ?
I thought, the packing is too tight in the middle of the column and I gave him instructions to pack it for his next trial. But now I think, perhaps you get the Sherlock Holmes award. He wrote me yesterday he uses this for retaining the scrubbies: https://www.stilldragon.eu/de/filtersch ... heibe.htmlYummyrum wrote:I have a three ring Banjo burner , it came with a standard Gas reg .I upgraded to an HP reg . See HERE ...picture tells a thousand wordsThanks for the effort.
I agree with pikey that the keg rim does act as a heat shroud , certainly at the power that you would want to stuck up this . I don't think the distance from the flame to the keg bottom is that much of a deal .The heat is pretty much contained in the keg rim .
I don't think he wants to saw the rim off as long there are other causes possible. And generally a longer distance helps against scorching (but will need a shroud or he looses too much propane).
But there is no point giving this still anymore power than it has already due to the flooding issues . Yes
Which is my next question .
Why can't the fluid drain back to the boiler ? Is there a mesh or holder in the bottom of the column to hold the packing that is causing a flow issues ? If so , it doesn't need to be there .Scrubbers will hold themselves in place .
A picture of the return system is in the middle of page 1. He is not the first one using a external return, but perhaps the first one using a pigtail at the end of the return. But for next trials he will remove the return to fix the other problems (mainly flooding) first.thecroweater wrote:One thing that does strike me as a small but significant design faut it the position of the take off valve and that blenky return line. I feel it would be far better to have the valve right against the column and remove that return line altogether. A diagram of the Internal construction of the head would clear this up straight away
A lad on the Swedish forums use the 3" version as perfplates and they hold the liquid at bay alright, vapour can come up but he uses a 1/2 downcommer to get return to the keg.der wo wrote: https://www.stilldragon.eu/de/filtersch ... heibe.html
I wouldn't use it for this application. It looks like the holes are too small to allow both vapor up and reflux down. But it's a stilldragon product for example for gin baskets. I think a gin basket should work in reflux mode too. What do you think?
Thanks a lot. So perhaps he should saw a few larger holes in it and perhaps at least the flooding problem is solved.Swedish Pride wrote:A lad on the Swedish forums use the 3" version as perfplates and they hold the liquid at bay alright, vapour can come up but he uses a 1/2 downcommer to get return to the keg.der wo wrote: https://www.stilldragon.eu/de/filtersch ... heibe.html
I agree ....It's totally not necessary to hold scrubbers in a column , If they are stuffed in good enough to work well , they hold them selves in placeder wo wrote: I wouldn't use it for this application. It looks like the holes are too small to allow both vapor up and reflux down. But it's a stilldragon product for example for gin baskets. I think a gin basket should work in reflux mode too. What do you think?
der wo wrote: But now I think, perhaps you get the Sherlock Holmes award. He wrote me yesterday he uses this for retaining the scrubbies: https://www.stilldragon.eu/de/filtersch ... heibe.html
Pintoshines idea, here: http://homedistiller.org/forum/viewtopi ... =17&t=6865thecroweater wrote:hole is the Liebig
You have pretty Names for my Works... Pig Tail- hole in the liebig nearby the valve (the tube has to be angled for this I think)
- hole at the top of the pig tail or removing it
00Speedy wrote:Ok "Wo", even German members don't know if I am wo or der or der wo...
I'll try the following things first:
Don't forget, you will need to have the liebig angled!- hole in the liebig nearby the valve (the tube has to be angled for this I think)
You have pretty Names for my Works... Pig Tail. This seems to be a special problem with Germans here. Look at the comments about my still http://homedistiller.org/forum/viewtopi ... 27&t=56682
Yummyrum sayed its a BastardI am sorry, but he said, you are the bastard, not your still.
I think you're on to something here, der wo. Since the liquid outlet (from the valve and plates) is lower than the liquid level in the plates, it will "pull" a suction when the valve is opened. The liquid return line to the column is larger than the opening of the valve, so the liquid will tend to flow into the return more likely than down the long path of the Liebig.der wo wrote:...it gives air another easy entrance and exit, the air doesn't have to get pushed through the whole liebig. The distillate will be able to flow faster through the liebig. Perhaps this is enough to fix it.
still_stirrin wrote: The liquid return line to the column is larger than the opening of the valve, so the liquid will tend to flow into the return more likely than down the long path of the Liebig. Only if the return was vertical too. But it's horizontal here. As long there is no sucking from the side, all the distillate will flow down to the valve.
As the condensate "tries" to flow down the Liebig tube, it needs an air relief vent to break the partial vacuum pulled as the liquid flows. Currently, air must suck up through the Liebig to relieve that partial vacuum, and that trades a steady liquid flow down the Liebig's liquid tube for the pulsing flow of liquid and relief air suction.
If the Liebig's liquid (condensate) line had a larger bore, perhaps even as large as the liquid takeoff from the plates, then the competition for flow crossectional area may not be so compromised. But a needle valve with such a large bore diameter would not allow to control the product as fine as we want. But angling the Liebig from vertical may also help solve this as well. I want him to angle the liebig mainly that no distillate will drip out the hole.
And, if you can get a pressure relief vent above the Liebig such that it doesn't try to flow condensate, then that solution might also solve the stability of liquid flow dilema.
This place is great...where experience and innovation join to solve problems. Perhaps we can solve "world hunger"...or thirst similarly.
ss Ah no, this is boring. I currently play with a valve, a few copper tubes and fittings and hot glue in my bathtub to find out more details about this issues of LMs. Much more fun than saving the wales or something.
Don't listen to him 00Speedy , he is trying to use your insecurities in English compehension to get me in troubleder wo wrote:00Speedy wrote: Yummyrum sayed its a BastardI am sorry, but he said, you are the bastard, not your still.
der wo wrote: Ah no, this is boring. I currently play with a valve, a few copper tubes and fittings and hot glue in my bathtub to find out more details about this issues of LMs. Much more fun than saving the wales or something.
Long time since I stumbled randomly to this thread. But now saw for the first time, that on the picture is a "sulfide gas venting hole" just where Pintoshine has the hole/vent at his LM path against siphoning. Do you have a link with the theory of this sulfide vent? Did you once try out, what happens when you block this vent (other than a burn blister on your thump)?thecroweater wrote:OK you had me confused with hole in the liebig, you are meaning a vent at the valve I guess in which case that return for sure has to go. Makes me wonder why the liebig at all if its to run in pot mode forget the vent. My old reflux still had a vent straight after the take off valve
http://homedistiller.org/forum/viewtopi ... 6#p7017750
Agreed - I think the pressure would be positive from the column, but what is to stop the rising gasses from entering the tube and creating a back pressure against the condensate flowing down ? Possibly even re-evaporating the condensate in the normal reflux way ? and leaving through the hole at the slant plate, where the pressure would likely be less ?der wo wrote:still_stirrin wrote: The liquid return line to the column is larger than the opening of the valve, so the liquid will tend to flow into the return more likely than down the long path of the Liebig. Only if the return was vertical too. But it's horizontal here. As long there is no sucking from the side, all the distillate will flow down to the valve.
