Here are some images that I have found:
"Ponu 1" "Ponu 2" "Ponu 3" 'Ponu 4" "Ponu 5" A possible modification of the last (not something I will try, but thought I'd add it anyway). My confusion:
In the diagram for "Ponu 1", it shows the largest tubing (going off to the right) as the one circulating back to the still, with the smaller tube being connected with the take-off porting that runs through the condenser. Also, this design has a vent to the atmosphere up the top (on the largest tubing). Also, I'm not entirely sure which tube is connected to the water-trap/lower coil. i find the same confusion with "Ponu 2". The difference with "Ponu 2" is that it does not show a vent to atmosphere.
"Ponu 3" is a detailed drawing though I am confused by the fact that the lower coil is connected to the take-off line as well as the secondary tubing that runs through the condenser. It is confusing for me because I was under the impression that the water-trap boiled off the vapor to be sent back up again, but the only way to the take-off tube is through the coil. Does this mean that the alcohol vapor is flashed off in the coil so that it rises up and through this take-off line and mixing with the liquid from the secondary tubing?
"Ponu 4" is a great illustration. If you remember that the coil has been removed from its chamber to show its purpose, as well as the fact that the coiling chamber has been split in half to emphases the different directions, then this shows how the ponu is operating. Also, the bottom of the lower coil is a little misleading, it remains pointed up so it does not go directly back into the boiler.
"Ponu 5" is proposed modification for the ponu. IMO I don't think it would work, at least how its proposed. It is an interesting idea though to increase the amount of reflux going on.
I do have questions: 1) How do you adjust the rate of take-off? A needle point value on the take-off line would only make liquid build up in the coil, and though some would go back down I'm not sure how helpful it would be with the ABV%/reflux action. Though maybe someone has a better thought on this? 2) Some designs have a vent to the atmosphere and some don't. Depending on where this is, I think this would merely let the vapor escape instead of being taken off. Is a vent necessary in this particular design?
I hope ozone doesn't mind this, but the following is from ozone about the action of the ponu:
I'm figuring out that these are the key elements..A--lower coil length, too long water flashes off with the alcohol, too short and the alcohol drops back into the pot. B-- The longer the distance between the secondary coil inlet and the lower coil inlet the smoother the still runs (this adds some height to the still, but minimal), shorter the distance and it "cycles the alcohol out more than flowing steady. As well you get two flash off and condensing cycles before it leaves the still, so you theoretically say it been double distilled.
Threads of interest:With a ponu it's all about surface area on that lower coil.... I was able to install a wide but short coil in the 6", with the 3" it would be a longer but narrower coil (more like the first one I built).
http://homedistiller.org/forum/viewtopic.php?t=14533" onclick="window.open(this.href);return false;" rel="nofollow < ----- ozone's 6" ponu.
http://homedistiller.org/forum/viewtopic.php?t=15323 < ------ hstuurman's ponu.
My plan:
I want to build a short and compact ponu probably using either 2" or 3" copper. I can definitely get 2" pipe but I'm unsure about 3" right now. Since I want this for an apartment I was thinking that the lower coil to be around 12"-18". I'm unsure about the length of the upper coil. According to ozone, the 'longer' the distance between the two the smoother the still will run. Since the second coil is sitting inside of a water-cooled chamber, the wider the chamber the more length of tubing could be used, theoretically (at least i think :S) the greater the distance. I'm trying to add as much length as possible without going that far up.
If anyone has any theoretical numbers or ideas to throw around, I'm all ears .
