the penny whistle experiment
Column still distillation and construction.
Re: the penny whistle experiment
Postby olddog » Tue Sep 21, 2010 2:13 pm
You may need a bleed off of some sort, as when you are taking product the flow is cut down to a trickle.
OD
olddog
Master Distiller
Postby Mr.Spooky » Tue Sep 21, 2010 2:16 pm
olddog wrote:You may need a bleed off of some sort, as when you are taking product the flow is cut down to a trickle.
OD
ok,,, ill have to try to figure something out on that....
spooky
Mr.Spooky
Postby Mr.Spooky » Wed Sep 22, 2010 5:52 pm
just got my grahm mounted on. im kinda questioning my compression fittings,,,, i got half a mind to take them off and just hard pipe it. who knows maby ill just see what hapens.
spooky
Mr.Spooky
Postby Kentucky shinner » Wed Sep 22, 2010 5:55 pm
Your gettin close spooky keep it up man.. cant wait till you get er up and running man...
Kentucky shinner
Postby LWTCS » Wed Sep 22, 2010 6:02 pm
Mr.Spooky wrote:im kinda questioning my compression fittings
Why so Spooky?
Postby Mr.Spooky » Wed Sep 22, 2010 6:09 pm
pretty much all i need to do is get the "rack" that the plates are gonna hang on mounted, and a parrot. im supose to pick up my music cork tomarrow, and my teflon sheet is supose to come in next week sometime.
my sweetfeed is about finished, and im assuming my peaches wont be far behind, so im gonna take the leftovers from the two and use for a cleaaning run,,, after the vinager and water.
spooky
Mr.Spooky
Postby Mr.Spooky » Wed Sep 22, 2010 6:16 pm
Why so Spooky?
i dont know,,, from my experience with that kinda stuff,,, if you dont get it right the first time, you dont get no second chances. it seemed like it set good,,, but well see.
the place that i feel like i messed up on was not leaving a lottle more pipe on each side of the compression fittings. i dident leave myself any second chances. if it dont work,,,, my grahm will need to be taken apart and the coil will need to be replaced. (worst case cenerio)
spooky
Mr.Spooky
Postby rednose » Wed Sep 22, 2010 6:40 pm
Indeed looks a little fragil Spooky.
What about getting a 1" version of this fitting in copper or brass and soldering direct to the condenser and the 2" cap?
Also a soldered to the column and bolted to the condenser support would help.
union 2.jpg (14.84 KiB) Viewed 158 times
rednose
Postby rockchucker22 » Wed Sep 22, 2010 6:54 pm
Looks good spooky!
if your gonna ride, ride the wild horse
rockchucker22
Master Distiller
Postby Mr.Spooky » Wed Sep 22, 2010 7:01 pm
rednose wrote:Indeed looks a little fragil Spooky.
The attachment union 2.jpg is no longer available
im not really worried about the weight being on it because i will have an adjustable table that will support any weight. this is just a rough mock up as how it will be,,,,, but my concern is the auctual connection at the compression fitting.
do you think that the table will support any aditional weight?
thanks
spooky
Mr.Spooky
Postby Kentucky shinner » Thu Sep 23, 2010 2:28 am
I used a 1/2" union and 1/2" pipe for mine and It worked just fine. I dont really think you will have to have your table to support your column, but I may be wrong.
I dont need any extra support for mine anyway and it does not look like OD needs any with his.
Kentucky shinner
Postby loneswinger » Thu Sep 23, 2010 10:24 am
I think as along as you do not take the graham on and off a bunch of times, you will be fine. Compression fittings are not really made for this. You could put a compression to NPT thread on both the output side and the graham side, then if you wanted to disconnect it, you could just unscrew the threaded part and leave the compression fittings attached.
+1 on a bleed for you pumped cooling water. How about a 3-way valve so that the more you restrict flow to your dephlag the more water is returned in an alternate loop.
Looking good though, I have been eagerly watching this thread. Nice to see it near completion.
-Loneswinger
It's better to learn from other people's mistakes than your own.
loneswinger
PreviousNext
Return to Column Distillation and Design
Who is online
Users browsing this forum: Bing [Bot], choppinlow and 7 guests
