Valve Plate design
Re: Valve Plate design
the washers will have solder on them. There should not ever be any thing to repair? With that said if you did you could cut the column and use a easy flange or just use a coupling. I did not make my flute nor did OD to come apart. It should give many many many years of service with no service aside from giving it a good rinse with water.
thats why (to me) it would be in best intrest to have a column that would accept interchangeable "plate trees"...rockchucker22 wrote:Oh you have insipered me I will build a valve plate to try with my bubble plates If it works better I could switch to valve plates easly, or a combo of valve/bubble/perforated.......oh so many ideas, so many combos
spooky
Where did you source the rivets from?
Hangover? I don't get no stinking hangover!
Some roofing supply companies do sell copper rivets.Drunk-N-Smurf wrote:Where did you source the rivets from?
If they sell copper drip cap and similar copper flashings they will stock the rivets as well.
Leather supply companies such as Tandy sell solid copper rivets.
DSP-AR-20005
DSP-AR-20005
McMaster Carr sells copper rivets in various sizes
