Prairiepiss wrote:condensificator wrote:how often did you anneal it while you were working down that lip?
how bigga balls does that harbor freight expander have to expand copper...like could you turn 2-1/2" into 2-3/4" or 2-7/8"?
good to see your project on the move!
good luck, keep us posted.
Sorry didn't see these questions the first time.
#1 Your not going to believe me but. I didn't anneal it at all for any of the work I have done to it. On the 3" condenser jacket that is.It was harder to work with but it was doing what I wanted it to. I just didn't want to change it by annealing it. I think If I would have annealed it. It wouldn't have turned out so good.
#2 Not impressed with these at all. I bought all 3 sizes they have. The problem they have for us is the sizes. The one that fits in 2" is the middle one. And 2.5" I think is its max. I did play with it a little on 2 " but stopped because of the outcome. It kinda makes it octagonal. You have to run it out a little then rotate it a little and run it out again. Doesn't end up round. The next size up will not fit into the 2" and fits 3" about the same as the one does in the 2". So if you want to use it like I did get it. If you want to use it to expand copper pipe. Save your money. Oh and this is what I tried to use on my centering ring I just posted pics of. The problem there was it only fit half way in. So when I tighten it it flares out on the open end. it flared it a little with a lot of work. And I annealed the shit out of it.
I've been working on it a little here and a little there. I've got some really cool shit built. I just don't want to let the cat out of the bag on that just yet. When I get closer the the end of the tunnel I will. That stuff goes with the 4" flute build for a latter thread.
Return to Column Distillation and Design
Users browsing this forum: Cardinalbags, Earlster and 3 guests
