Bokabob Build Questions
Column still distillation and construction.
Re: Bokabob Build Questions
Postby seaguy » Fri Apr 06, 2012 8:03 am
Got my mesh here for free shipping http://www.amazon.com/s/ref=nb_sb_ss_i_ ... Caps%2C273 There is no need to weld fittings into a keg to go electric. Search my posts.
2" x 5' Boka, 3/8" coil / 3/4" cold finger, 15gal 220v 5.5kw heater, Tincup's controller
seaguy
Postby WV Shine » Fri Apr 06, 2012 1:36 pm
seaguy wrote:There is no need to weld fittings into a keg to go electric. Search m
+1
Absolutely no need to weld... my silver soldered keg connections are all holding up just fine ;) Only a tad harder than copper-copper. Just read the tutorials here, get the right flux (Harris Stay Clean works great for everything), and make sure you clean and tin everything well.
WV Shine
Postby seaguy » Wed Apr 11, 2012 5:18 am
I have a hole for the heater element and that's it. When I finish a run I hand truck it out in the yard and tump it over. oh.....Tump is Southern for "tip over" :) When empty I rinse with a garden hose then drain n dry inverted on a couple of 4x4s. Havent noticed a need for anymore holes in the keg. Ocaisonally I slosh around some Winebottle cleaner in it. The boiling mash does my sterilizing :ewink:
seaguy
Postby eworthin » Wed Apr 11, 2012 2:08 pm
Just an update on Discovery Valves - my valve came in last week, it's a monster. It weighs over a pound and is about the size of my palm. Still works fine to control the flow, it just looks massive hanging off the end of the boka's 1/4" tubing outlet. At least it's only SS & teflon. Just a forewarning to anyone concerned about aesthetics.
eworthin
Previous
Return to Column Distillation and Design
Who is online
Users browsing this forum: Bing [Bot], drinkingdog and 6 guests
