bentstick wrote:+1 on bigger is better for final condenser, i figure ya can fit 12 in there with no problem, dont see any reason with that much tubeing to go much longer than 12/14 inches, put the cooling to it and run like hell wont have it!
Prairiepiss wrote: 2700 watts is the most I have at this point. But it knocks down every bit of it. With just a trickle of water. I think you should have a good balance of water mass and number of tubes.
To little water mass with to many tubes you need a ton of water flow. It can handle a ton of vapors but knocking them all down is hampered by how much water flow you have. And flow can be hampered by having to many tubes in the path. The water needs to flow around all of them easily or you will have hot spots.
To much water mass and not many tubes not very much water flow is needed. But it can't handle as much vapors.
When I originally designed mine I had plans to use 9 1/2" tubes 11" long. The shell is 16" long with a gin basket at the inlet end.
Bushman wrote:Oops I new that but I guess I am still 3 hours off after getting home from Hawaii!
Glad you made it home safe. Return to Column Distillation and Design
Users browsing this forum: bigfish909, Richard7, Stilly and 3 guests
