Are sight glass necessary
So i'm going to build a new tower and was was thinking something plated (maybe one packed to). I have no experience with plated columns, but have read a lot (have a lot more to go) and haven't found anywhere talking about it sight glass was a must have to properly run a plated column? They do look really cool and i'm sure theres times they might help diag a problem (also add a lot of expense), but are they mandatory?
Re: Are sight glass necessary
Not necessary at all but nice to have if you can afford it. Never hurts to have a window into the soul of your woman, uh, column.
No but thangs can go south quick you usein one on a fair size kettle
So I'm tole
So I'm tole
goose eye wrote:No but thangs can go south quick you usein one on a fair size kettle
So I'm tole
South in a good way or bad
I don't get that either Goose Eye ? Expound please!
Professional boilers always seem to have them...
FS
FS
Do it Safely read The safety section: http://homedistiller.org/forum/viewforum.php?f=33
New Distillers Reading: http://homedistiller.org/forum/viewforum.php?f=46
Hookline's Basic Still Designs: http://homedistiller.org/forum/viewtopi ... =1&t=18873
- thecroweater
sight glasses on a column don't actually effect the still, there are guys that just have one sighty on the bottom plate. I think you would want to be a very experienced column stiller to run with none
- MitchyBourbon
No, but then you gotta be Obi Wan Kenobi, especially until you're dialed into how it runs. Are you dialed into the force?
I'm goin the distance...
I wish I never put that sight glass on my still!
Said no one ever.
Said no one ever.
- MitchyBourbon
So true. bearriver, you are an enigma. You should be studied.bearriver wrote:I wish I never put that sight glass on my still!
Said no one ever.
Definitely not dialed in, Yet.MitchyBourbon wrote:No, but then you gotta be Obi Wan Kenobi, especially until you're dialed into how it runs. Are you dialed into the force?
Bottom line
So I'm tole
So I'm tole
kinda like timing the old car without the timing light... takes the guess work out of it... avoiding some serious problems, or major inconvenience.
She was just a moonshiner,
But he loved her Still
Yup!bearriver wrote:I wish I never put that sight glass on my still!
Said no one ever.
Using Google Search
Using Google Search
Thanks for clarifying your first post goosegoose eye wrote:Bottom line
So I'm tole
- MitchyBourbon
That there is funny. Good.one, both of you.woodshed wrote:Thanks for clarifying your first post goosegoose eye wrote:Bottom line
So I'm tole
How bout its the bottom line with the two lines.
that help any
So I'm tole
that help any
So I'm tole
Agreed. Both have there place on a column but the thermos will be of more benefit.rockchucker22 wrote:Thermometers would do also most as well but you would need one on the bottom and one on the top plate. I have thermos on each plate and use that data more than the glasses.
However, they don't look as COOL.
Actually it does.goose eye wrote:How bout its the bottom line with the two lines.
that help any
So I'm tole
My first plated column had no sight glass, I had only had a pot still before that. the first time I ran the plated I was like a chook running around without a head!, what's that sound, what's this sound, I have no idea what my plates are doing!. I eventually got it running ok with some help from someone on a forum while I was running it. After a few runs I couldn't stand not seeing what was happening inside, so I put one glass in the bottom plate. It was like a window into heaven!, I could see wtf was going on!. I still only use one on the bottom. You can run without them but just takes the guessing out of it, and you will learn more about how you run being able to see, plus it's very very exciting seeing them bubbles
"Homer J Simpson"
"Homer J Simpson"
- jedneck
More fun than watching an airlock work.
big help
Dunder
big help
Dunder
Took this during sac run on Betty. Running hard and fast. This was at 19 amps.
- MitchyBourbon
- thecroweater
hmm a thermometer on a still let me get back to yaz on that (don't have one), my flush port was made to hold one in the RC never saw the need
I usually sight my glass, before I drink. Sometimes, because of various chemical equations, I see two glasses.
From my fuzzy memory, sight glasses are a good indicator of oncoming tails, that is when the plate begins to dry out.
When things go South it's not a good thing. Absolutely no offence to Southerners, I'm one myself.
I typically only use the therm on my boiler anymore as it beeps at me at a preset temp so I know when to turn on the cooling water.
Normally I have multiple things going on at once in the distillery and can't waste the time watching it and would rather not waste the electricity to run the pump all the way through the heat up process. Even if it is 12 volt. I am a cheap bastard. Once it beeps at me I am all about the still or within reach until well into hearts. Never out of sight of the still. I even have an window in the wall separating the still room from the rest of the place so I can see it from my most used workbench.
Only my 4 plate has a therm on the column. Could be pulled but i'm geeky that way and have gotten use to glancing at it towards the end of the run. Certainly cheaper than adding a sight glass and will give you the same info once you have her figured out.
The sight glass will speed up that figuring out.
http://youtu.be/rcBVn-Zh-wI" onclick="window.open(this.href);return false;" rel="nofollow
"Homer J Simpson"
"Homer J Simpson"
