Newbie column build
Re: Newbie column build
Ceramic rasching rings are a quite well known column packing. There is nothing alarming about using them, just a matter of the right size for your power, column size, etc. If you can get your hands on enough to pack a column I would certainly give them a try. A short packed section on top of a few of your plated sections should do great for a neutral vodka if you wanted. A 4 foot packed column over one plate will certainly give a fine vodka. If you have some to experiment with, take advantage.
Using Google Search
Using Google Search
Actually I have a shop pool going on for tonight's drawing I'm working with the powers above me to get a price on a barrel of these!rgreen2002 wrote:...this is like stumbling upon the Leprechauns Gold! The barrels and the raschig rings to boot!?!!! What number do you like for the lotto tonight?
I've talked to the managers and am getting a price on an 88lb barrel of these. If I can secure a barrel of these would there be people interested in them? If so I would be happy to take orders for them and ship them outHound Dog wrote:Ceramic rasching rings are a quite well known column packing. There is nothing alarming about using them, just a matter of the right size for your power, column size, etc. If you can get your hands on enough to pack a column I would certainly give them a try. A short packed section on top of a few of your plated sections should do great for a neutral vodka if you wanted. A 4 foot packed column over one plate will certainly give a fine vodka. If you have some to experiment with, take advantage.
Let us know if you can and post in the classified thread. Give a hint here so we will know to look though.
Using Google Search
Using Google Search
10-4 no problem!Hound Dog wrote:Let us know if you can and post in the classified thread. Give a hint here so we will know to look though.
Ok so last night I ran my first water run. Got what I think was full reflux in about 45 minutes at 100% throttle. I say "what I think was full reflux" because the sight glasses were so fogged up I could see anything really...if I looked close I could see bubbling on the plates tho!!! It was exciting!! I had the dephleg and condenser being cooled with a 5 gallon bucket of water and a pump...that didn't last long because you could boil a hotdog in the bucket after that 45 minutes running lines to the water valves I have in the garage today so I get a constant temp water feeding the condensers. Progress!!
If you didn't have anything coming out of the product condenser then it was full reflux. Good job. Some guy's designs have a hard time knocking back a straight water run. If it does that it will always knock down the vapor from a wash because the boiling point of a wash is lower and the vapor is not as hot.MX450248 wrote:Got what I think was full reflux in about 45 minutes at 100% throttle. I say "what I think was full reflux" because the sight glasses were so fogged up I could see anything really...
Using Google Search
Using Google Search
That was my thought thanks HD for the feedback! I'm getting the parts together to tap into my city water line in my garage so I have a constant temp water feeding the condensers...I could use my pool but doing this on the back porch would raise some suspicions I'm going to do another water run after I get the new water lines hooked up and see how it works thenHound Dog wrote:If you didn't have anything coming out of the product condenser then it was full reflux. Good job. Some guy's designs have a hard time knocking back a straight water run. If it does that it will always knock down the vapor from a wash because the boiling point of a wash is lower and the vapor is not as hot.MX450248 wrote:Got what I think was full reflux in about 45 minutes at 100% throttle. I say "what I think was full reflux" because the sight glasses were so fogged up I could see anything really...
The new water lines won't change much as you had full reflux going on but do as you wish. You will always have vapor fogging the glasses if running water it the boiler need the alcohol in there to clear the glass. That said a 5 gal bucket won't cut it for a run but you will work that out
AC
AC
I had full reflux until the cooling water got way too hot to touch...once that happened vapor started to pass through. That's why I'm going with the city water to see what it does.acfixer69 wrote:The new water lines won't change much as you had full reflux going on but do as you wish. You will always have vapor fogging the glasses if running water it the boiler need the alcohol in there to clear the glass. That said a 5 gal bucket won't cut it for a run but you will work that out
AC
You still had full reflux when the glasses fogged. Do the vinaigrette. Then some alcohol in it and tell us what happens.
AC
AC
I've tried looking up vinaigrette but I didn't come up with much from the HD Google Search...there were posts that mentioned it but couldn't find the descriptionacfixer69 wrote:You still had full reflux when the glasses fogged. Do the vinaigrette. Then some alcohol in it and tell us what happens.
AC
Now...expanding on your tips here...would say a 3 foot packed column on top of say 3 of my plates give me an out-of-this-world vodka? I see myself needing more 4" copper pipe unless I can make the packed section out of stainless that I have plenty ofHound Dog wrote:Ceramic rasching rings are a quite well known column packing. There is nothing alarming about using them, just a matter of the right size for your power, column size, etc. If you can get your hands on enough to pack a column I would certainly give them a try. A short packed section on top of a few of your plated sections should do great for a neutral vodka if you wanted. A 4 foot packed column over one plate will certainly give a fine vodka. If you have some to experiment with, take advantage.
I use 4 feet on top of a single plate and it is great. And yes, go for it in sinless if you have it! If you can TIG great! If not, Harris Staybrite8 and liquid flux will do the trick.MX450248 wrote:Now...expanding on your tips here...would say a 3 foot packed column on top of say 3 of my plates give me an out-of-this-world vodka? I see myself needing more 4" copper pipe unless I can make the packed section out of stainless that I have plenty ofHound Dog wrote:Ceramic rasching rings are a quite well known column packing. There is nothing alarming about using them, just a matter of the right size for your power, column size, etc. If you can get your hands on enough to pack a column I would certainly give them a try. A short packed section on top of a few of your plated sections should do great for a neutral vodka if you wanted. A 4 foot packed column over one plate will certainly give a fine vodka. If you have some to experiment with, take advantage.
Using Google Search
Using Google Search
- raketemensch
I couldn't wait to have a plumbed feed for my dephleg, right up until my wife set off the dishwasher, and my stability went out the window... Or the washing machine, or someone flushed a toilet, etc.
I'm not saying it can't be done, but have a stable feed means having a stable stream. I learned the hard way.
Oh yes sir...TIG is what I do for a living! I've got more stainless pipe laying around than I know what to do with lolHound Dog wrote:I use 4 feet on top of a single plate and it is great. And yes, go for it in sinless if you have it! If you can TIG great! If not, Harris Staybrite8 and liquid flux will do the trick.MX450248 wrote:Now...expanding on your tips here...would say a 3 foot packed column on top of say 3 of my plates give me an out-of-this-world vodka? I see myself needing more 4" copper pipe unless I can make the packed section out of stainless that I have plenty ofHound Dog wrote:Ceramic rasching rings are a quite well known column packing. There is nothing alarming about using them, just a matter of the right size for your power, column size, etc. If you can get your hands on enough to pack a column I would certainly give them a try. A short packed section on top of a few of your plated sections should do great for a neutral vodka if you wanted. A 4 foot packed column over one plate will certainly give a fine vodka. If you have some to experiment with, take advantage.
That is a good point...what pressure does your house water supply run at? Is it city water or well? The pressure to my house is around 55-60 psi on a 6" water main and a 1" feed coming into my house. I know ultimately that a spike or drop at a given faucet in the house is determined by a multitude of things including pipe routes through the walls, pipe size, run length, etc. Just wondering if we are on the same playing field with supply?raketemensch wrote:I couldn't wait to have a plumbed feed for my dephleg, right up until my wife set off the dishwasher, and my stability went out the window... Or the washing machine, or someone flushed a toilet, etc.
- raketemensch
I'm on a well, it produces like mad because I basically live in a swamp. I've never measured the pressure, though.
You should have a pressure tank that should build to around 50psi...if too many things are turned on at once you're pressure will drop below your pump can react to make it up. I grew up on well water and we were always fighting that. With city water I'm hoping to have more steady flow even if the wife starts the washer or somethingraketemensch wrote:I'm on a well, it produces like mad because I basically live in a swamp. I've never measured the pressure, though.
Ok so after much searching...the HD forum and Google...I have come to the conclusion that a "vinaigrette" run is made with vinegar to clean the nasties or of the new still. My question...does it have to be pure vinegar or can it be diluted? It takes 6 gallons to cover 2" above my heating element.
Well water pressure will vary between pump cycles by as much as 15lbs or more. I have installed a simple cheap inline drip irrigation pressure regulator to maintain a constant water pressure of 25lbs.
Yes dilute the vinegar. I would dump in 2 gallons ND fill her up and run off a gallon or two.MX450248 wrote:Ok so after much searching...the HD forum and Google...I have come to the conclusion that a "vinaigrette" run is made with vinegar to clean the nasties or of the new still. My question...does it have to be pure vinegar or can it be diluted? It takes 6 gallons to cover 2" above my heating element.
Using Google Search
Using Google Search
Awesome thanks HDHound Dog wrote:Yes dilute the vinegar. I would dump in 2 gallons ND fill her up and run off a gallon or two.MX450248 wrote:Ok so after much searching...the HD forum and Google...I have come to the conclusion that a "vinaigrette" run is made with vinegar to clean the nasties or of the new still. My question...does it have to be pure vinegar or can it be diluted? It takes 6 gallons to cover 2" above my heating element.
Got the still all hooked up to my water supply today. Here are some pics...
Also insulated the boiler to be more energy efficient.
Should do fine...yes sir, just fine.
Good looking setup you got there, MX.
Thanks ss...looking forward to my vinaigrette run tomorrow. Hopefully I can get my first sugar wash fermenting tomorrow also can't wait!! It's getting exciting!!still_stirrin wrote:Should do fine...yes sir, just fine.
Ok got some video of the vinaigrette run last night. It was a learning experience! Total of 5 videos in all but they aren't that long this is the first...let me know your feedback! Now watching the videos I realize that I used some incorrect terms what can I say I was excited
https://youtu.be/kz1C3HREsPk" onclick="window.open(this.href);return false;" rel="nofollow
https://youtu.be/g1fIJ323O8o" onclick="window.open(this.href);return false;" rel="nofollow
https://youtu.be/cu8bJKhOiw8" onclick="window.open(this.href);return false;" rel="nofollow
https://youtu.be/n-qavEmxqgY" onclick="window.open(this.href);return false;" rel="nofollow
