3" CCVM with lava rock report
Finally got to do my sac run on a 3" condenser controlled vapor management a la DAD300 and others:
15 gal keg charged with 15% low wines/feints
5000w element
2-3" adapter from keg
3"x40" copper section packed with dime/nickel size black lava rock, copper scrubbie at each end of packing
Stainless 3" T and 3" elbow leading to 2" all copper shotgun product condenser
1/2" Stainless gas line reflux condenser
Started full blast at 5kW. Listened to what I assume is the much discussed "aquatic environment" climb column. Lots of gurgling/bubbling etc. Brand new experience for me, ive run potstills 98% of the time. When I started to get nervous about an overflow into the takeoff, I reduced power to about 3700w. Set cooling water so it exited the condenser hot (forgot to take actual temp, call it 130F) Equalized for less than 10 min andd started inching condenser up. Had azeo from the first drop, continued increasing takeoff to 1 gal/hour. Maintained purity for a quart, then shutdown.
I think some glass is in my future but overall I'm very pleased and excited. Thinking about trying lava rock? Go for it.....
Thanks to all who paved the way with the new generation of packed columns.
5000w element
- BoisBlancBoy
Re: 3" CCVM with lava rock report
Good work Chroi. That's very good numbers for a first run. Time to get yourself some wash fermented and get that thing producing! Some pictures of your setup would be awesome.
Just curious how you cleaned your lava rock and how long it took you to do it? I'll be curious to hear your future success.
Rinsed in hot water until the water was clear, then boiled, rinsed again 2-3 more times.
I'm very pleased, was expecting to add another 20" packed section.
I'll try and get pics, camera on phone is broken but it doesn't look like much, certainly nothing like some of the builds on here.
- BoisBlancBoy
Did you maintain azeo at the 1gal/hr rate? I think that's what you meant just wanted to confirm.
Yup. Need to get a narrow range alcometer so I can really see the nuances at higher proof, I have a standard 0-200 proof one and it works fine but 94vs95vs95.5 is hard to judge
- thecroweater
Add temp corrections and ain't that the truthChroi wrote:Yup. Need to get a narrow range alcometer so I can really see the nuances at higher proof, I have a standard 0-200 proof one and it works fine but 94vs95vs95.5 is hard to judge
- BoisBlancBoy
thecroweater wrote:Add temp corrections and ain't that the truthChroi wrote:Yup. Need to get a narrow range alcometer so I can really see the nuances at higher proof, I have a standard 0-200 proof one and it works fine but 94vs95vs95.5 is hard to judge
I've never seen one, do they make narrow range alcometers?
- thecroweater
For sure they do but I have only seen them used in commercial spirit safes so they'd gov approved and costly, I don't know if ya can get them cheap on line
Saw one on eBay the other day for like $20, the whole unit measured between 90-100% so small increments were easily distinguished.
No idea how accurate it really was, but seemed interesting.
I've order this set from ebay, and should be in next week or I hope so.. with let you know how they work out.. a friend has a set and said they work good but I've not work with them, yet..
http://www.ebay.com/itm/162248196751?_t ... EBIDX%3AIT" onclick="window.open(this.href);return false;" rel="nofollow
Mars
Mars
– Albert Einstein
– Albert Einstein
