1. Added bigger radiator
2. Added 2 new fans
3. Using frozen milk jugs
This is a follow up to my previous post I have made many improvements, the induction heating is working beyond expectations!
I modified a large A/C window units condenser, then added two 9 inch fans ! Gives me 200 percent better cooling for long runs, to help even further I add 2 milk jugs I freeze overnight as needed I can run for 4 hours at 88 F temp control is critical for oils.
Re: CM Compound Still Improved !
Re: Re: CM Compound Still Improved !
... now you just need to replace that plastic funnel.
________________
It was a water run! Lolgreggn wrote:... now you just need to replace that plastic funnel.
