Yeah, my control box has 24VDC in it so I just used that.
You can set the on/off point on the fly very easily.
The
green LEDs show your flow rate and you just move the red one left or right to set the trip point. I guess far left is no flow but I have it set to the point where the condensers just start to get overwhelmed.
You just hold down the right arrow on max flow for a few seconds to calibrate the range.
Very simple.
I use it to drive a (TPDT?) relay. When off, the power to the pump is killed and so is the SSR signal. The relay also drives a flashing buzzer (although I killed the noise bit).
That's why I had to add a start button to override it and get the pump going.
Some details are
here
I will go a different way if 2.0 ever happens but this thing works fine for now. I just drive the PID controller on manual.
It was also intended to run a HERMs system but I'm not done making rum yet (I've even done a few meals with it as a sous vide cooker
Looks like I accidentally bought that proportional valve for 50 bucks too
, I just hope the
flow rate is useful.
It'll probably be fine with a pump but I'll have to do the numbers before I try to use it on anything.
Edit to add - I may have misunderstood your question, check out the output on the data sheet. You only get a visual indicator of flow rate with this model. It's just a fancy switch.
The flowphant gives a 4-20mA flow (& temp) output but they cost a lot more and I don't think they're very accurate.
