While I was looking for the parts to make the PSR-25 I stumbled on these locally and I was wondering if they would work for a 220V, 5500W heating element?
Omron - G3NA-240B
Control voltage: 3-32vdc
SPST "Contact": 24-250 VAC 40 Amp
• Features compact dimensions (2-1/4L" x 1-11/16" X 1-1/8") to provide a uniform mounting pitch.
• Built-in MOV varistor effectively absorbs external surges.
• Operation indicator (red LED) enables monitoring operation.
• Protective plastic finger cover for greater safety.
• Screw terminals provide quick and easy connection
• Certified by UL and CSA
I've attached the datasheet.
