Any electricians in the group?
Aside from stills, much equipment is involved in the process of distillation.
Postby fullhouse » Tue Jan 31, 2012 2:32 pm
I have a few Questions about wire size and such for wiring my LAB lol...my meter base is about 120 feet from the lab.it is a 200 amp base.i want to put a electric stove unit,5500 watt element for my boiler,AC unit (prolly a 110 window unit lab is 10x16),outlets and lighting,and a small hotwater tank (just a 10 gal or so just to for sink use). i feel good that i can do the wiring ok just need to know the size wire i would need to get this done and also the size box to put next to my meter base and in the lab i will proly go with a small breaker box in lab to save trips to the main box next to the meter ....thanks for any help with this
3' Essential Extractor PSII High Capacity (Brewhaus) on gas,recirculating 60 gal olive barrel for cooling
Employ your time in improving yourself by other men's writings, so that you shall gain easily what others have labored hard for ~ Socrates
fullhouse
Re: Any electricians in the group?
Postby MuleKicker » Tue Jan 31, 2012 2:42 pm
I would run 200A service cable then. 2/0 copper, or 4/0 aluminum. consult local electrical code.
-Control Freak-
AKA MulekickerHDbrownNose
MuleKicker
Postby moonshine guy » Tue Jan 31, 2012 2:46 pm
So I think that you want to run 220 vac to your lab. What size btu will the ac be? And will the hot water heater be 110 vac with 1500 watt heater?
moonshine guy
Postby fullhouse » Tue Jan 31, 2012 3:10 pm
thanks for fast replys..the ac will be 10,000 btu and water heater will be 1500 watt yes...i may see if i can find a inline water heater as it will not be used much and wont need to hold hot water heating it all the time
fullhouse
Postby fullhouse » Tue Jan 31, 2012 3:22 pm
ouch that 2/0 stranded copper is 3.06 a foot and id need 3 of them right?
fullhouse
Postby Nimrod » Tue Jan 31, 2012 3:29 pm
2/0 might not be big enough! You have to consider voltage drop at that distance. 120ft is right at the teeter point.
You will definitely need 2 you can downsize the neutral to 1/0 and then I would do atleast #4 ground.
QUICK! Don't CLICK HERE!
Please Click HERE to visit New distiller reading Lounge
RGB
Nimrod
Postby fullhouse » Tue Jan 31, 2012 3:41 pm
ouch u fellas sure dont encourage the wallet any lol....ok so if i drop the stove was just thinking since i have it yanno..guess i could use a hot plate if i needed to do some stove type stuff...and water could be heated in my boiler inconvenient but ...what if didnt go all out on a 5500 watt boiler....ac is a must tho as with lighting and such lol...i was told i could use 6/2G to run the lab but wanted more input on it b4 i did it
fullhouse
Postby Nimrod » Tue Jan 31, 2012 3:55 pm
6/2 would carry about 60 amps, but not 120 feet. It would also either give you just 2 hots or one hot one neutral....
RGB
Nimrod
Postby fullhouse » Tue Jan 31, 2012 4:02 pm
so 6/2 would keep me at 110 not the 220 that i would like to have right?if thats right would the it carry enough for the lights and ac and smaller watt boiler element?i may need to just stick with my gas burner setup i may just need to get a larger tank for my gas! the small ones are just such a hassle
fullhouse
Postby Nimrod » Tue Jan 31, 2012 4:08 pm
Yep, you are right. just 120. 6/2 has a ground in it, but it's not worthy or smart to use it as a neutral. I would go #2-120ft (x2), #4-120ft , and a #6 bare copper for conduit ground. Put 100 amp indoor panel in the lab. Wire as needed via standard romex. As per NEC :) .
RGB
Nimrod
Postby Nimrod » Tue Jan 31, 2012 4:13 pm
Gives 23 amp for the 5500 boiler. 20 amp for the AC, 20 amp for HW tank. If you do florescent lighting go with the T8 Electronic they are miliamps. 2 20 amp circuits for plugs ought to be ample for that size. But I sure like all my dedicated runs I made in this house :)
*Edit, just seen you put 1500w HW tank. Thats is 12.5 amps. It would be good to keep that dedicated, but you could cheat a few plugs on that circuit, just be aware not to run anything power hoggy on it.
RGB
Nimrod
Postby Tater » Tue Jan 31, 2012 4:22 pm
When I wired my shed I added a ground rod to breaker box ground same as for house breaker box I was pulling power from for additional safety.
PLEASE READ THIS FORUMS RULES AND THESES Links: http://homedistiller.org and New Distiller Reading Lounge I use a pot still
Tater
Master Distiller
Next
Return to Related Hardware and Appurtenances
Who is online
Users browsing this forum: No registered users and 3 guests
