Copper Kettle
Copper Kettle
I have an old copper kettle that I was thinking about using on a still project but its a 2 piece kettle and Im not sure what its was put together with. Its a dovetail type joint ..Any ideas on how the old copper pots were made??
Experience is something you don't get until just after you need it.
- Truckinbutch
Re: Copper Kettle
With lead solder would be my guess . If it has a wired rim the core of the roll is probably steel or galvanized steel wire .
Re: Copper Kettle
here is a pic. I had planned to use it for a sink in a log house but I hate to waste copper.
Re: Copper Kettle
Yes that is the line I was wondering about
Re: Copper Kettle
From what I can see there may be solder? If so I would check it with a lead test kit that you can pick up at just about any hardware store. If it's brazed or welded you should be good.
Re: Copper Kettle
It isn't soft like solder. Maybe silver soldered but being that its as old as it is I was unsure..
Re: Copper Kettle
I would test it for lead just to be safe because of the age. It would be a shame for that much copper to be a sink! If it test lead that would make a great sink.
Re: Copper Kettle
I went to Walmart and they didn't have a test kit so Ill try Lowes tomorrow. Thanks for pointing out the test kit..
Re: Copper Kettle
sure looks like braze to me,(brass)
Re: Copper Kettle
I agreeDnderhead wrote:sure looks like braze to me,(brass)
Re: Copper Kettle
I tested it for lead and everything looks good. I guess it's time to shine it up and put it to good use
Re: Copper Kettle
Re: Copper Kettle
well I finally got around to using the copper dome. Ive been so busy on doing things for everyone else I havent had time to do anything for myself. With all the rain in the south lately I had a few days to work on my own project lol.
- der wo
Re: Copper Kettle
Wow! Welcome! A thread returned from the dead. Grrreat still. Did you need 3 years for that?
Re: Copper Kettle
Nice looking rig mate
"Homer J Simpson"
"Homer J Simpson"
Re: Copper Kettle
thanks. Hopefully it wont take me 3 more years to find the time to finish it .lol
Re: Copper Kettle
I actually only have about 3 days in it so far. I never have time to work on my own stuff. Its like a paint and body guy that always paints everyones car but his own.der wo wrote:Wow! Welcome! A thread returned from the dead. Grrreat still. Did you need 3 years for that?
- BTR Kentucky
Re: Copper Kettle
Very nice! Did you build the flute part?
"He is not a fool to give the things he cannot keep, to gain the things which he cannot loose"
Re: Copper Kettle
Damn...!!! That's one tall flute...!!! Nice use of that copper bowl...
Do you have sight glasses and plates started yet...???
Re: Copper Kettle
yes I built everything but the candy kettle. I have more pics but didnt think anyone would be interested in the inside. Seen on seen em all kind of thing.BTR Kentucky wrote:Very nice! Did you build the flute part?
Re: Copper Kettle
I have the sight glasses and clamps already and the plates are already in and soldered in place. Ill put a few more pics up. Im not sure how its going to run with 8 plates and only being 4" diameter.rad14701 wrote:Damn...!!! That's one tall flute...!!! Nice use of that copper bowl...
Re: Copper Kettle
here are a few more pics.
- Location: Next to the bent tree and the crazy neighbor!
Re: Copper Kettle
Wow, I'd say this one is in the top five nicest flutes I've seen! Excellent job! Olddog would be proud of this one if I may say so!
- BTR Kentucky
Re: Copper Kettle
Very nice still porn
Re: Copper Kettle
I got the boiler finished and decided to wrap it in Cypress that I had left over from a canoe. I still have to make the openings to access the elements and the drain that will come out of the front and tons of finishing but its starting to come together. Im out of time for now so it will have to sit for 5 more weeks which will be my next days off.
- Danespirit
Re: Copper Kettle
I am impressed...!
You did some damned fine handyman work there...congrats to finally finishing your still.
It's not every day we see a 8 plater with a copper dome and such nice woodwork.
Hmmm...makes my enclosure on my boiler look very humble (I plan to put some wood around it and insulate).
Speaking of insulation...are you planning to use something like Rockwool or just foam it up in there..?
The handles will be cut off your boiler I assume..?
- MichiganCornhusker
Re: Copper Kettle
Hubba hubba, that is truly inspiring, beautiful concepts and work!
So much amazing talent on this forum.
Re: Copper Kettle
Yes the handles are cut off and just using a water heater blanket for insulation.
