2" copper flared with triclamp to keg question
bingo
Post by bingo »
If I flare a piece of 2 inch copper will this work to connect to a keg with a triclamp? Thanks in advance.
googe
Re: 2" copper flared with triclamp to keg question
Post by googe »
Sure will mate. More a flange than a flare though.
"Homer J Simpson"
Braz
Post by Braz »
Braz
Samohon
Post by Samohon »
No problem with that method. Tried and Proven...
Heres a gasket to union it with...
I used Olddogs method to make the easy-flange....
♦♦ Samohon ♦♦
googe
Post by googe »
I personally think the easy flange is to much work and prefer just a simple hammered flange.
"Homer J Simpson"
maheel
Post by maheel »
googe wrote:I personally think the easy flange is to much work and prefer just a simple hammered flange.
+1 with a triclover seal (or home made one) they work great
drill a 50mm hole in some hard wood
anneal your pipe
work around the pipe slowly
once your here flatten it right out
and you done :)
i do the flange 1st so you can slide it back out....
thelegion
Post by thelegion »
good work, I've spent way too much time searching for flanges and adapters welding them on and etc...
thanks, thelegion
googe
Post by googe »
So true thelegion!, I too got sick of trying to sorce parts and thought stuff it I'll give it a go myself, it's so easy to do everyone should try it.
"Homer J Simpson"
Tap
Post by Tap »
Very nice, thanks for the easy tutorial. Am I correct in saying that you Flanged the pipe out 1/4"? effectively making the flange 1/2" larger in diameter?
thanks
Too much of anything is bad, but too much good whiskey is barely enough
ebourlet
Post by ebourlet »
After annealing do you find that it work hardens enough that It will support its weight if used as a column?
Shine0n
Post by Shine0n »
Absolutely
