In this thread: http://homedistiller.org/forum/viewtopi ... 8#p7285988 bearriver says:
bearriver wrote:I would find out how much heat it takes to flood that column, then back off until the flooding becomes settled above or inside the packing. If you can keep the flooding just above the packing in a safe and controlled manner (stable) then it will perform much better. I call running in this fashion the sweet spot for my reflux still.
I also seem to remember Dad posting a similar video with the same comment.
I believe both were right in that the column held >90% until the sight glass suddenly fogged signaling the onset of tails which it did quite suddenly, by the way. The glass was bubbling merrily along, I looked down at the parrot and when I looked up less than ten seconds later found this:
I marked that jar by situating it with an empty between where the sight glass was bubbling and the tails where the bubbling suddenly stopped and the glass fogged. The difference between the jars was striking and added a new way for me to find the tails in a run without using my senses of taste and smell after airing out.
Here's a pic of the old column with a new window:
Oh! And if today wasn't cool enough, I repurposed this portable swamp cooler to supply cooling water to the condensers. I found it almost new on top of everything in a dumpster a while back and finally got around to swapping the dinky onboard pump to the fountain pump that I was using in a barrel full of water which heated up pretty good by the end of a run. The still stayed nice and cool throughout a 4 hour run and used about three gallons of water in evaporative cooling.
Needless to say, I've had a great day with the hobby today!
tp
