Portable fermenting cart
Since my son moved back home and lives downstairs I lost my downstairs bathroom where I did my fermenting. Just finished insulating this large cart with a removable insulated front. Holds my heater and four six or eight gallon fermenting buckets.
bellybuster
Re: Portable fermenting cart
Post by bellybuster »
perrrrrfect
is that a repurposed tool chest??
No it's a really large AV cart used in education that I purchased from surplus supplies.
johnarms
Post by johnarms »
that looks pretty sweet Bushman! its a bitch to move them around without wheels sometimes. :clap:
I used to ferment in a downstairs small bathroom with a heater and aquarium temperature controller while doing fermentation but as mentioned I moved it into the outbuilding on this portable cart and retired the aquarium controller to a drop light. Not only did I regain the bathroom the light works great and uses much less electricity.
Below is a link to my aquarium controller, wiring is the same just switched the heater for a drop light.
http://homedistiller.org/forum/viewtopi ... 85&t=25475
PS: what I didn't mention is I put L bracket son the bottom to hold the front and use ratchet straps to pull it in. Makes it easy to remove and get to the different fermenting buckets.
BoisBlancBoy
Post by BoisBlancBoy »
Looks great! You should have went bigger hahaha!
dieselduo
Post by dieselduo »
wish I had something with wheels. getting old makes it brutal schlepping buckets around
BoisBlancBoy wrote:Looks great! You should have went bigger hahaha!
Actually I can hold 4 eight gallon fermenters at a time, I have 6 gallon fermenters keeps me busy enough.
BoisBlancBoy
Probably smells great when it's full and fermenting away when you walk by.
bearriver
Post by bearriver »
That's great Bushman! Everything in a garage should be so lucky to sit on Castor wheels.
Looks big enough to keep you busy all winter. :thumbup:
BoisBlancBoy wrote:Probably smells great when it's full and fermenting away when you walk by.
:thumbup: :thumbup: :thumbup: Gives me a reason to keep going out to the outbuilding.
Stonecutter
Post by Stonecutter »
Bushman seriously Bad Ass! Being a tool guy, I definitely nerd out on carts.
A fine example of K.I.S.S.
-Thomas Paine
juana_b
Post by juana_b »
That's good enough to put on 20" castors with rap music over it.
― Charles Ives
juana_b wrote: Wed Jan 05, 2022 6:06 pm That's good enough to put on 20" castors with rap music over it.
:thumbup:
