New parrot
New parrot
Never had a parrot. Just built this guy to use with my new shotgun condenser build. Not pretty but functional. I'll get to use both for the first time in a few days.
Re: New parrot
That will work
Maybe a little difficult to read the abv accurately "down the tube" as it were, but it will work.
Re: New parrot
Pikey, the inside tube is the same level as the outside reducer. It overflows into the reducer and out to the jar. The numbers are up high
Re: New parrot
nice work, if you build another one add in a dump valve. that way you can dump your fore shots first and when you get to your tails and shut the rig down it makes for an easy clean.
I'm just the bank and the mule
post your still pics here
http://homedistiller.org/forum/viewtopi ... 16&t=66917
