How could that happen?SaltyStaves wrote:Good point. They may also scorch if the copper is hot enough.NZChris wrote: Cyclonic action throws heavy particles to the outer wall and they run back down with the reflux.
I want to make a jin basket.
Re: I want to make a jin basket.
- SaltyStaves
If there is no reflux at the point they spatter the wall.
iron gauze will rust quickly, copper or stainless steel will not.Kareltje wrote: You could turn the riser into a gin basket by making a sieve or an iron gauze in the bottom of it.
Hey.NZChris wrote:A lot of the flavors you want are oils and getting rid of them is a mistake.
Putting a tube in that lets vapor escape without passing through the botanicals makes no sense at all.
Most botanicals work very in the boiler, so packing everything into a gin basket isn't always the best option. I use three different still configurations for gin, the only one I run with all of the botanicals in the gin basket is a Carter Head.
I realized that the basket of jeans should not be wide, so that the steam would move faster.
Show the picture (carter head)?
I have no idea what you are talking about. There is no place on any gin still design that I know of where that could happen.SaltyStaves wrote:If there is no reflux at the point they spatter the wall.
- SaltyStaves
You're no doubt right.NZChris wrote:I have no idea what you are talking about. There is no place on any gin still design that I know of where that could happen.SaltyStaves wrote:If there is no reflux at the point they spatter the wall.
I heard it from some mouthpiece for Bombay Sapphire talking about why they place their botanicals where they do.
Of course I can no longer find it.
My bad: you are right.cob wrote:iron gauze will rust quickly, copper or stainless steel will not.Kareltje wrote: You could turn the riser into a gin basket by making a sieve or an iron gauze in the bottom of it.
And what is more: he found a better and more beautiful solution!
Cheese,
Did you ever make a gin head/basket??
13.5g/50L keg
26g 4" stripping still
5500watts of fury
5500watts of fury
