packing idea
packing idea
getting tired of buying copper packing to pack ss column, was wondering if anyone sees a problem with packing a column with 1/4 or 5/16 copper rings cut from a length of pipe, sorta use them like raschig rings?? I know a plumber that can obtain all the scrap copper I need
Re: packing idea
nope, that'll work just fine
I'm just the bank and the mule
post your still pics here
http://homedistiller.org/forum/viewtopi ... 16&t=66917
Re: packing idea
Yes, will work fine.
I made a lot of curls of copper thread, the kind used in home electricity nets.
- Danespirit
Re: packing idea
That will work...just be sure to clean them thoroughly before you fill them in the column.
However, you'll discover a lower HETP opposed to the copper mesh....so the efficiency of the column drops a little.
Re: packing idea
thanks guys, thought it would be ok just wasent sure
Re: packing idea
why not get a roll?
https://www.amazon.com/Copper-Blocker-P ... B01MU71HPN" onclick="window.open(this.href);return false;" rel="nofollow
Re: packing idea
I have discovered you can only clean copper mesh so many times and it seems to start to get brittle, I just soak mine in a vinegar/water solution then rinse, i run my still a lot, is there a different way I should be cleaning it? I just use column for strips and then run them through my 8 plate 4" flute
- rgreen2002
Re: packing idea
hpby98 wrote:why not get a roll?
Look around. I've bought 100 ft for under $30!
HD Glossary - Open this
Re: packing idea
another idea I kicked around was the ground wire that is in electrical wire cut into thousands of pieces or even rolled into tight spirals kinda like small springs????
thoughts????
thoughts????
- Danespirit
Re: packing idea
Certainly, you could do that.
You just have to be sure you can clean AND dry it afterward.
If moisture gets trapped inside between the wires, it will oxidate pretty easy....leaving you with some green stuff in there.
