6" or 4" Keg Top Ferrule
Hello folks, I have been distilling for a while and thank you for letting me join the forum.
I am going to build and electrically heated keg. I can't decide whether to weld a 4" or 6" ferrule on it. I know I could just use the 2" on it now. I will probably use that for the bottom and a drain. Most folks seem to stop at 4". I think I would like a little more room to get inside so I am thinking 6". I plan on using a concentric reducer to go to 4" or 2". I know that will be a lot, about $80.
Has anyone done a 6" ? Is it much more difficult?
I figure I will be around for another 25 years. So in the long run if it is better, I'll do it.
I presently have a 15 gal stock pot with a 2" copper pipe in the lid. Eventually, I hope to build a 4" bubble column but can run this keg easily attached to the same worm I have now.
- MitchyBourbon
Re: 6" or 4" Keg Top Ferrule
Welcome to HD JoeFL77,
A 4" column is probably as big as you want to go on a 15 gallon keg. That said, if you got the skills and the resources to put a 6" hole on a keg I say go for it. Cleaning will be easier, you will be able to look inside easier too.
I'm goin the distance...
Welcome Joe and pretty much same as Mitchy. If $ isn't issue I say go for it.
money could be the deciding factor, price out each size to reduce down to your column and see if its worth it. anything above 2" starts to climb in price very quickly
Do you plan on distilling on the grain??
I'd get an reducing adapter to use with the original sanke valve. There are suggestions that a reduced diameter feeding the column will provide some benefit in a reflux column. A very recent thread is bumping around here on that exact subject.
A clean out port works really nice on the side of the keg. Think about how long your arms are. As well, you would have more options for a gasket material due to it being out of the vapor path. Someone posted an affordable manway solution a few months back...
Thanks for the info.
Money is always an issue but I think it will be worth it.
I may still on the grain. I have only done UJSSM so far. I used my simple stock pot pot still.
I had a tough decade and didn't get much stuff done other than working a lot for little. Recently things have gotten much, much better. My wife is much better and things are looking up. I have bought a lot of stuff like a monster mill, a mini 3-1 lathe/mill, and lots of other things I hope to finally have fun with.
I hope to malt some corn. Do some all grain. Use the big stock pot to cook while the keg to still.
I read this web site a lot and look forward to using all the tools in the workshop.
Thanks again!
Thanks again!
Bearriver,
I was typing when you posted so I didn't see your reply. I might use one of those end cap reducer. That would be the equivalent of keeping the 2" opening. I could go smaller too. So many options and so many unknowns.
Thanks for info.
Thanks for info.
6" is 50% bigger, and 2x the price of 4". And you need a ferrule, a clamp, and a reducer. Not even considering the cost of a drill bit... OR the drill you need to make that sucker turn.
If you really want a 6" opening on a keg boiler, I'd add a separate 6" fill/cleanout port. But for a column attachment, 4" ferrule is going to cover about any type of still head you will be able to drive out of that size of boiler.
I agree with Bob, a member Mash Rookie experimented with a 6" column and said that the boiler would have to be larger than a keg to drive it.
just saw this post while i was looking for info on grain mills. i have a keg and did put on the 6" ferrule. then used a reducer to 4". i can tell you that is the way to go. yes, you can use the 2" opening and a 4" workswell also. but, when i put on the six inch it did two things. first cleaning is a breeze and second with the reducer i gained extra length in my column and the opening allows for mor evaporation. some will say it doesnt matter. however, my notes would disagree. the only thing i might do over would be to get a y reducer. that way i could add a 90 and fill without doing a complete tear down.
I'm just the bank and the mule
post your still pics here
http://homedistiller.org/forum/viewtopi ... 16&t=66917
- bluefish_dist
One more for 6". Personally my arm won't fit through a 4", so bigger is better for cleaning.
Formerly
Dsp-CO-20051
Dsp-CO-20051
