Greetings from South Africa
Greetings to all
I'm from Pietermaritzburg, South Africa. I'm new to the site and the world of micro-brewing. My first still I've almost completed is a Boko Reflux Still. I've used Stainless Steel as the material.
- MoonBreath
Re: Greetings from South Africa
Welcome to HD!
You are new to this site and also the hobby and have already almost completed a stainless boka build? Wowww, you had to have some guidance somewhere, please tell us all more ..And pics if possible.
Enjoy the required readn, site, and journey.
Good luck, do be safe.
- Truckinbutch
Welcome . I know little of your area except through the eyes of Wilbur Smith . He makes it sound enchanting .
Hi MoonBreath
hank you for the kind words. I've used HD as my main guidance so far. I've taken a few pics of the column parts that are finished. I'm left with finding a suitable packing and completing the coil.
- der wo
Hi Vincent,
welcome to the forum.
It doesn't look like if your still is vented at the top. It's very important for safety. You simply could drill a hole besides the water in and out.
- Danespirit
Greetings and welcome..
Wow..I must say it's a nifty column you've build there.
However, I have just one remark....is the end cap on top vented to atmosphere?
It should be or you'll have a bomb when the valve is closed..!
You have probably come by Crankys spoonfeed thread, if not please have a look at the link in my signature.
Have fun and stay safe....
Welcome Vincent. We had another new member from S. A. about a year ago. Went by Fidel Naidoo. He was an absinthe enthusiast, seemed like a nice guy. He disappeared suddenly and mysteriously in the middle of a conversation we were having by PM. It was very odd. I hope you will stick with us longer. Your work so far looks good. Keep the pics coming.
He disappeared suddenly and mysteriously in the middle of a conversation we were having by PM. It was very odd. I hope you will stick with us longer. [/quote]
Hippos,leopards,crocodiles,lions....
Welcome V
Welcome V
Deo Vendice
Deo Vendice
Hi All
Thank you for all the kind remarks. jb-textshine....the only place we have hippos, croc, lions etc are in our national parks. So Fidel definitely didn't succumb to any of those. Well technically not, unless he visited a park of course.
der wo and Danespirit thank you both for bringing that to my attention. I have read in numerous places about the venting to the atmosphere but it seems only for other still types. Although I fully understand the logic behind the need of a vent or pressure release what I do not get is this. If a reflux column has a vent at it's top end then surely all the evaporated ethanol will escape via this vent? Or am I missing something ?
I can answer this for you. A CM still is run similar to a pot still in that it's design is never closed by a valve. An LM and VM still is open at the top but vapors should not escape through the top unless you do not have enough to knock down the vapors during reflux. If the valve is closed and does not have an open system as a pot and CM still have then pressure could build up and create a bomb. The opening at the top of the other reflux stills allows for this escape in the event that you do have a blockage and pressure builds.Vincent wrote:Hi All
The vent is a requirement on any reflux still that has a control valve that is closed during heat-up and equilibrium... As Bushman stated, all LM's and VM's require a vent if the reflux section is capped off... This is a safety concern that should be addressed immediately if there is no vent...Vincent wrote:Hi All
Or you do not use the clamp just let it sit on top of the column, that would releave the pressure if builds up.
Yes I am a Novice with 40+ years of doing this hobby
distilling is like sex the slower the better and everyone is happy
fermenting is opposit to sex the faster the better
This is just not good advice to be providing in these forums... If the cap jams you still have a potential bomb... We take safety very seriously here and you should too...papapro wrote:Or you do not use the clamp just let it sit on top of the column, that would releave the pressure if builds up.
I guess you are right Rad I also take safty very seriously that is why I do not use any direct heating elements,
and my column has 2 inch openning.
- Danespirit
The ventilation hole to the atmosphere serves two purposes.Vincent wrote:Hi All
1. You need it to prevent pressure is building up, or you'll end up with a pipe bomb instead of a still (so no need to worry about leopards or the like, the still will kill you ).
2. If you don't have it, your still won't function at all. As the contents in the boiler heat up, there are also created a variety of uncondensable gasses.
Those gasses have to escape somewhere...
A common question from new distillers is about condensing the vapor generated.
Ethanol is liquid as up to 77-78 C (depending on your height over sea level).
This means as long as you condenser is below that temperature, you'll have liquid Ethanol.
It takes surprisingly little cooling capacity, to knock down those vapors. As your reading progress, you'll understand it better.
Just an example...my coils for 2" columns: http://homedistiller.org/forum/viewtopi ... 87&t=52290
Just to be clear:
Leave the whole top open. It is the reflux condenser that keeps vapor from escaping. A cap has no purpose at all. The R.C. forms the boundary. Everything above it should must be atmosphere.
