Hello every one
I'm new to this although have been distilling for a few years now! I have a reflux Collum attached to a modified 50l beer keg for a boiler.
I have seen a lot of posts regarding problems with water flow regulation with turbo 500 Callum's and similar.
Although it is easy for me because I live in the bush and the only water I have is tank water, I believe the best way to have a constant flow of cooling water without pressure fluctuations is to gravity feed it.
I have a header tank on a 3 metre high stand which I pump bore water into. The water then gravity feeds into my house to feed the toilet the yard taps and my still.
I realise this is not suitable for people in the cities but it is quite easy to set up a drum on a stand higher than your still to gravity from.
This eliminates the need for expensive pumps and regulators.
Cheers.
Hello form Nth QLD Australia
Re: Hello form Nth QLD Australia
Welcome! Sound like a reasonable play to me. How big is your tank, Matt?
- Still Life
Hello, Matt.
Glad you have your set up working for you.
Come on in and enjoy the experience.
Welcome!
Welcome!
gday old mate!
Modular 2" Pot Still
- thecroweater
welcome here, what you say is a fact and i could do that here but your coolant is limited to the flow your gravity allows. You ever need more,hot day or what ever you can whistle dixi
