Refractometer Question
MashMaker
Will a refractometer acuratly read a finished wash or is it only acurite on a distilled spirit?
- thecroweater
Re: Refractometer Question
depends what its calibrated for most are calibrated to read brix which can in turn can be used via some formula to work out the ABV of spirit or there are dedicated spirit refractometers available
FtW
A refractometer is similar to a hydrometer for specific gravity, it reads the sugar content so used on a wash rather than a distilled spirit. It can give a number on a finished wash, but some math has to be done to account for alcohol in the wash.
Advantage of a refractometer is the wash doesn't have to be clear to work, it can have solids in it that could mess with a hydrometer reading.
- der wo
A hydrometer has the advantage, that sugar effects the mesuarement in opposite direction as alcohol. So you can measure more exactly and calculate better the remaining sugar and the reached abv of a finished wash.
With a refractometer both push the result in the same direction.
Edit: Yes! I'm Bootlegger now!
MashMaker
Thanks for all the info got my question answered
- DAD300
A hydrometer is a dumb instrument...it gives a reading for whatever it is calibrated for. There are hydrometers calibrated to read battery acid.
An alcolometer is calibrated to read the percentage of alcohol versus water and assumes you have put it into a water and alcohol only solution. Solids in a finished ferment (yeast, sugar, grain leftover) will queer the reading.
Same with refractometers, they cam be calibrated for dif solutions. Water/sugar, water/salt, water/alcohol...get the right refractometer for the solution you are trying to read. Just remember solids will queer the reading.
DSP-AR-20005
DSP-AR-20005
- Kegg_jam
Had an interesting observation the other day. Checked the Brix on unmalted rye and malted barley mash after an over night mash.
The clear measured 13 Brix. 2 lb / gal. Was a little bummed. Transferred to fermenter and whipped up real good to aerate. Measured Brix again before pitching .... 15 Brix. More like it.
So the first sample was nice and clear, second one was more like translucent. Did the solids in the sample affect the reading or was the sugar concentration sort of layered down through the settled mash pot?
- DAD300
Good question...Match it against an SG Hydrometer and let's hear the reading.
DSP-AR-20005
DSP-AR-20005
I had something similar happen as Kj
Measured the clear from the top of an all grain mash. The refractometer and hydrometer both said 1.042
Several hours latter after the mash was all muddied up by fermentation, the refractometer said 1.045 ?
On a side note: I'm taking a crash course on refractometers.
rager
i think i noticed the same thing. the real clear mash at the top after the first mashing hour or so would read low SG like 1.03ish, after i stirred the same mash and let it clear again the SG would be much higher. going from 1.03 to 1.06 in 20 minutes of clearing after the stir.
my guess is the sugar are heavier so the will "sink" during the first stages of mashing..... so after you stir it up it will give you the more accurate gravity of the mash.
yes , no ?
- thecroweater
What do you guys think about 0 to 90% brix calibrations? I was hoping to get one I could test both the mash and fermentable like molasses, honey ect
- Oldvine Zin
I haven't used my sg hydrometer since I got my refractometer, so far I've not had any issues with my ferments -- all good with the refract
OVZ
OVZ
- Oldvine Zin
Damn I'm not sure what I would do with juice at 90 brixthecroweater wrote:What do you guys think about 0 to 90% brix calibrations? I was hoping to get one I could test both the mash and fermentable like molasses, honey ect
OVZ
- NZChris
0-90 Brix would have tiny graduations at OG levels. Mine is 0-30. If I want to check molasses, I add water to quadruple the sample volume, then multiply that Brix by four.
