Deer Corn
Deer Corn
Postby *MoonShine* » Fri Nov 10, 2006 2:38 pm
Is plain ole' deer corn "whole kernals" ok to use?
*MoonShine*
Postby Tater » Fri Nov 10, 2006 3:28 pm
Sure is. Just needs to be broken up some or cracked as its called.Please think about where topic should be posted.{I moved this one from recipes]
PLEASE READ THIS FORUMS RULES AND THESES Links: http://homedistiller.org and New Distiller Reading Lounge I use a pot still
Tater
Postby *MoonShine* » Fri Nov 10, 2006 4:00 pm
What is the reason for cracking the corn?
I already mixed everything "Without" cracking it, gona be ok?
*MoonShine*
Postby Tater » Fri Nov 10, 2006 4:43 pm
might should of read a bit dont ya think :roll:
Tater
Postby *MoonShine* » Fri Nov 10, 2006 4:46 pm
I did read, the only thing I could find was that cracking the corn exposes the starches in the middle.....
If I am using sugar for the alochol and corn for the flavor....
I am still going to get flavor cracked or not....right?
*MoonShine*
Postby TRANSPLANTED HILLBILLY » Fri Nov 10, 2006 4:53 pm
theres a hull on that corn that will keep the flavor inside
If it was easy everybody would do it.
Please join the Partnership For an Idiot Free World.
Postby junkyard dawg » Sat Nov 11, 2006 11:24 am
would that corn taste better if you sucked on a kernel or chewed it up?
junkyard dawg
Master Distiller
Postby *MoonShine* » Sat Nov 11, 2006 5:12 pm
Acutally I tried that..... couldnt taste any difference.
*MoonShine*
Postby OzarkWhiskey » Sat Nov 11, 2006 5:14 pm
Actually I have found that once the corn is soaking in the water it will swell and start to split somewhat.
You will get more flavor from cracking the corn... but you will get some flavor without cracking it.
"I Strive For Prefection Not Progress"
OzarkWhiskey
Postby junkyard dawg » Sat Nov 11, 2006 7:06 pm
moonshine, what 'exactly' is it that you mixed up? You'll get corn flavor that way. I haven't tried this, but I think that If you broke that corn up some and made more surface area then you'd get more corn flavor. Depends on your taste... and what your gonna do with it. If your gonna put it in a small barrel for a while then go for the big flavor.
Also, if your using malt in your recipe then that starch is all potential alcohol. There is a distinct flavor that comes from fermenting common cane sugar and whole corn and a different and distinct flavor from fermenting corn starch converted with malt. I like the corn and malt...
junkyard dawg
Master Distiller
Postby *MoonShine* » Wed Nov 15, 2006 8:23 pm
I used....
5 Gallon water
7.5 Lbs Sugar
5 tsp Yeast Nutrient
?About? 6 Cups of Deer Corn "It was just handy"
I used (2) fermentors so I have double the ingredients above.
As of now I have no desire of letting it age. I want just "Good Ole Shine"
Last one made was with sweet feed. Very Good Shine "Everyone is begging for more! :(
*MoonShine*
Re:
Postby RScottyL » Mon Jan 12, 2015 9:20 pm
junkyard dawg wrote:would that corn taste better if you sucked on a kernel or chewed it up?
What you just described is "Chicha":
In some cultures, instead of germinating the maize to release the starches therein, the maize is ground, moistened in the chicha maker's mouth, and formed into small balls, which are then flattened and laid out to dry.[7] Naturally occurring ptyalin enzymes in the maker's saliva catalyses the breakdown of starch in the maize into maltose. (This process of chewing grains or other starches was used in the production of alcoholic beverages in pre-modern cultures around the world, including, for example, sake in Japan.) Chicha prepared in this manner is known as Chicha de Muko.
RScottyL
Re: Deer Corn
Postby bearriver » Tue Jan 13, 2015 9:54 am
That poster hasn't been seen here in almost a decade.
Holy thread resurrection Batman!
bearriver
Return to Grains
Who is online
Users browsing this forum: No registered users and 2 guests
