When making bourbon/american whiskey and following the traditions in the process, you would have come across the sour mashing method. This involves using a portion of the set back/backset/stillage from the previous run to introduce into the new mashing. If anyone doesn't have much experience with this process, it does not have to do with introducing a sour flavour into whiskey...it's main objective is to lower the pH of the mash and be able to maintain some consistency throughout multiple runs. As set back is very acidic it is effective in bringing the mash down to an optimum level for corn mashing, and helps to prevent bacterial infection. The other benefits to sour mash is that the lactic solution can introduce what some would label as "creamy" flavours and supposedly provide a degree of mouth feel. As far as i'm concerned though, it's all about the pH control
When you are doing your first run and don't have any set back, a sour corn starter is a method which can allow replication to some extent of some of the effects of the sour mash. Here's the process...
Fill up a few jars/containers with some corn. I got cracked corn, and chucked it in the blender for 10 seconds just to break it up a little bit. You'll need at least 4 jars, because they don't always work....
Pour filtered/boiled water in the jars to a minimum of half of the height again on the corn on top. Make sure the water is at fermentation temp (maybe 26-32 deg C / 79-90 deg F). The idea here is that we are giving the natural yeast/bacteria a wet environment to start fermenting. You will notice the water cap turn white as some of the starches dissolve into the water. Put some paper towels over the top and leave them sit in a standard fermentation area.
After 24 hours you should notice that some form of fermentation is underway and there will be little bubles all through the corn, some working their way to the top and possibly pushing small particles to the top forming a cap of floating pieces.
There are 3 particular bacteria that we are lookingto take hold, one at a time, the next denaturing the previous one. Once the first fermentation is underway and the bubbles are visible, there should be a creamed corn like smell, which is the first of the three bacteria in action...
