popped corn
popped corn
Starting another popcorn mash this weekend you guys should try this there is no easier way to mash corn. This time I'm going to pop it in the oven I a large paper bag
- culvercreek
Re: popped corn
Going to have to look into this. Seems like their may be a use after all for that old hot air popper that I have move around the house a couple hundred times over the years.
Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote. Benjamin Franklin
The trouble with Socialism is, sooner or later you run out of other people's money- Margaret Thatcher
Re: popped corn
Interesting. How about sharing your popcorn whiskey recipe. What SG does it start at, what ABV do you end up with. Do you add sugar ect.
BG
BG
Re: popped corn
It's AG do a search for Popcorn not popcorn Sutton that's the name of my thread.boda getta wrote:Interesting. How about sharing your popcorn whiskey recipe. What SG does it start at, what ABV do you end up with. Do you add sugar ect.
BG
Re: popped corn
Last time I started with two pounds of popped corn per gallon and around 1/4 pound malted 2-row barley per gallon of water. I boiled my water turned the heat of and started adding my corn. I let the temp drop to around 150 and add my malt and then I cover my pot and hold the temp around 145 for 45 minutes. Cool the mash. My SG was 8 percent it finished at 7 percent ABV. This weekend I'm going to use two pounds of popcorn and half pound of malted 2-row barely per gallon I'll start heating my water and add my corn as I bring it up to mashing temp. I'm not going to waste time boiling water and waiting for it to cool.
Re: popped corn
I Know this thread is older than Dirt
However I’d like more about it
"poppedcorn" is anyone using this as their regular go to when making corn shine
To me is seems an easy way to cook
I did a search here and goog and there isn’t much on it
Other than posts from "cooper sweat" here on HD.Org
I believe the search would have more outcome if the famous Popcorn had a different name
Any info appreciated
Tommyt
Tommyt
Re: popped corn
Go to? Nope. But I have done it. I did pretty much the same as listed above, but if you still gotta gelatinize then all you're really doing is trading popping for milling. And if you do big batches, do you have any idea how much volume 50 pounds of popcorn takes up? Milling is easier than popping large amounts.
