jb-texshine - would crushed oyster shells such as this sold at Tractor Supply be acceptable. It's a chicken feed supplement.
http://www.tractorsupply.com/tsc/produc ... _vc=-10005" onclick="window.open(this.href);return false;" rel="nofollow
or
I had ph crash , I think, on my last ferment, too.
Both washes stalled in less than 12 hours
Re: Both washes stalled in less than 12 hours
-Just need something else to build. -
either one will work or just go by your local oyster bar and get some shells for free. I like the whole shells better because you can reuse them
- Skipper1953
I use crushed shells because they are cheap, readily available AND re-useable.
I put them in a coarse mesh bag along with a sealed Nalgene bottle to make the whole works float. When the ferment is finished, I dump the crushed shells into a pan and rinse them well with hot water.
- thecroweater
Actually according to HDNB's research ( that I haven't checked) you can in fact invert the sugars of agave syrup. The fracturing of the polysaccharides would in fact make them much easier to ferment the way I see itrad14701 wrote:Now, that would be a real trick if it was true... Unfortunately, you didn't make any unfermentables fermentable because, well, they're unfermentables... Meaning that they contain no fermentable sugars or starches that can be converted into fermentable sugars... Hence, unfermentables...midnightmaraude wrote:I'm sure it helped but I pasteurizing it and boiling it up may have made some unfermentables fermentable.
thecroweater wrote:Actually according to HDNB's research ( that I haven't checked) you can in fact invert the sugars of agave syrup. The fracturing of the polysaccharides would in fact make them much easier to ferment the way I see itrad14701 wrote:Now, that would be a real trick if it was true... Unfortunately, you didn't make any unfermentables fermentable because, well, they're unfermentables... Meaning that they contain no fermentable sugars or starches that can be converted into fermentable sugars... Hence, unfermentables...midnightmaraude wrote:I'm sure it helped but I pasteurizing it and boiling it up may have made some unfermentables fermentable.
Can you link to HDNB's research (not sure what HDNB is)? Are you saying the sugars can be inverted strictly using heat?
i did some reading on this last year, not really research and posted a comment earlier in this thread just trying to help out.
But if you use HD google search up there^^^ and type in " agave", there is a fair jag of reading and some reasonably good documentation on tequila recipes.
now i drink for evil.
