Another stuck fermentation...
Hey all,
I'm trying a molasse ferment for the first time and it's stuck. Here's the data:
4 kg fancy molasses
1,5 kg dark brown cane sugar
12g yeast nutriments
Juice from 1 lemon
60g Red star baker's yeast
20L water
OG: 1,075 (mesured with a refractormeter)
I'm stucked at 1.030.
My PH is around 5 (i have bandlets, hard to tell between 4 and 5)
I made sure the yeast was at room temp before pitchin it in water (that was at 38oC, as instructed on the package)
I mixed touroughly at a 30 min interval for 2 hours after pitching my yeast, before closing the lid with airlock
my room temp is 21oC (wich is kinda low for baker yeast)
so when it stops at 1.030, i went another way and tried 2 packs of EC-1118 (at room temp, and activated in water at 40oC, as intructed on the package). I tought that my room temps was too low, maybe.
1 week later, i'm still at 1.030...and i'm a bit at loss.... my ph is good, technicaly, my room temperature is ok for EC-1118 (i had good results on other ferments) and it's still stuck.
Nothing here: http://homedistiller.org/forum/viewtopi ... 61&t=42748 seems to apply to my situation..
Bad EC-1118? Try again?
Crushed oyster shells? still, my PH seems to be ok...
Heater belt?
What are your toughts?
Thanks a lot!
4 kg fancy molasses
Juice from 1 lemon
20L water
Heater belt?
Thanks a lot!
Re: Another stuck fermentation...
You might be done.
Big OG --> big FG in rums at least. Plus, its really hard to tell what the true FG is because of all the solids in molasses.
How does it taste? Is it sweet, or dry?
p.s. - next time, using bakers yeast in your rum, ferment it warm...like in the tropics. Your 21*C (70*F) is too cold. You should ferment at 32*C (90*F). You'll get more natural rum flavors out of it, with less hassle on attenuation.
I have to agree with SS here. Sounds to me like it's done. It's really difficult to get a true gravity reading at any point on a molasses wash because of the unfermentable sugars.
When you repitched the 1118, it didn't take off because there was nothing left for them to consume.
For future reference, bakers yeast likes a temperature range of 75F/24C - 85F/30C (higher is also ok for bakers yeast) and will start into the dormancy phase around 70F/21C... So your wash is too cold for bakers yeast... The wash temperature drops throughout the fermentation cycle so you may need to add auxiliary heat in order to keep your wash fermenting along...
A big thanks to you guys!
I'll surely try to heat things up a little the next time i use bakers yeast. From what i read, a lot of people seems to get good results with them for rhum. At the moment, i had better results with EC-1118 on other types of wash. I suspected that it was partly because of the temperature, as you pointed out to me.
Still_stirrin: it's really dry to the taste. I never thought it could mess up an SG reading that much...! 0_0
Ahyhow, it's all great advices! Thanks!
Something else might be going on: bakers yeast (Saccharomyces cerevisiae) primarily ferments glucose but really can't handle fructose very well and there is an awful lot of fructose in molly to start with (10-12%) and when sucrose of broken down - either by inverting or by the yeast itself - it produces equal amounts of glucose and fructose so you end up with even more fructose than what you started with.
Try pitching a Brettanomyces strain like BSI-Drie (a brettanomyces bruxellensis varient), Wyeast 5112 and WLP650 are B bruxellensis strains too.
http://brettanomycesproject.com/dissert ... hing-rate/" onclick="window.open(this.href);return false;" rel="nofollow
http://onlinelibrary.wiley.com/doi/10.1 ... 0329.x/pdf" onclick="window.open(this.href);return false;" rel="nofollow
"A little bit of oops goes a long way."
FuelMaker: that's a really interesting topic! Thanks for the links, i'll look at them!
Wow. I knew learning to distill great products was going to be a lifetime ''work in progress'' but never i tought it was going to be THAT vast (? i'm french speaking, i feel like don't find the correct way to express what i'm trying to do here..anyway)
I'm so thanfull for this awesome community!
Never would have guess.Antoinebegcou wrote: i'm french speaking
Deo Vendice
Deo Vendice
If this is the case ,maybe you can tell me why it is that hundreds if not thousands of hobby distillers world wide are using Bakers Yeast to very successfully ferment Molasses washes?FuelMaker wrote:Something else might be going on: bakers yeast (Saccharomyces cerevisiae) primarily ferments glucose but really can't handle fructose very well and there is an awful lot of fructose in molly to start with (10-12%) and when sucrose of broken down - either by inverting or by the yeast itself - it produces equal amounts of glucose and fructose so you end up with even more fructose than what you started with.
Or why companies and labs that specialize in cultivating bakers yeast for profit do so on a growth substrate of molasses....
Deo Vendice
Deo Vendice
- Windy City
I would be careful about using a Brett in my equipment unless it was glass or stainless that could be sanitized afterwards.
I have made a lot of rums and have spiced with many an item but Brett's wet horse blanket flavor has never came to mind nor would I ever try it.
Well, i'm sitting here eating popcorn reading your comments guys! Interesting arguments going on here!
- Windy City
Check out the tried and true recipe for Pugi Rum.
Try the yeast bomb. I believe you will be very happy with it.
Also pick up a refractometer cause moly hates a hydrometer
still waiting for you to post your spiced rum recipe, Windy. i'm pretty sure i can move it to tried and true and sticky it without riding too much heat.
now i drink for evil.
Have you run this wash yet, if so what did you get from it ? Was there the alcohol in it that there should have been ?
See first post in thread Windy..he is already using a refractometer.Windy City wrote:Also pick up a refractometer cause moly hates a hydrometer
- Oldvine Zin
At the winery that I work at we go through great sanitation protocols to prevent brett contamination and destroy anything that is infected with it. As far as I'm concerned brett has no place in my beverage (sorry to all the whacked out beer brewers who like it)
OVZ
OVZ
- Windy City
See first post in thread Windy..he is already using a refractometer.[/quote]Windy City wrote:Also pick up a refractometer cause moly hates a hydrometer
Oops I missed that
I'm going to run it tomorrow morning! I'm going to do a follow up on what i collect!Saltbush Bill wrote:Have you run this wash yet, if so what did you get from it ? Was there the alcohol in it that there should have been ?
Well, i'm currently running the wash and i now have a nice steady stream and my thermometer (it's calibrated and placed directly at the entrance of the condenser - i have a pot) indicate 91oC. I tried a calculator from the parent site and is it possible that I have a 12% wash...?
http://homedistiller.org/calcs/alcohol_content" onclick="window.open(this.href);return false;" rel="nofollow
Am I right?
Am I right?
- cuginosgrizzo
No, you are registering the temperature of the vapor. The temperature of the boiling wash is different (higher)
oooooOOH! Should've known that! Thanks for pointing that out!
I felt 12% was out of the place.... LoL My guest is i'm around 6-7% max. Oh well.... we'll see once it's over!
I got 4,75 L from a 23L wash. Ran till I hit 20%.Saltbush Bill wrote:Have you run this wash yet, if so what did you get from it ? Was there the alcohol in it that there should have been ?
Smells incredibly good, even if it's low wines...!!
