moving mash into larger container from smaller?
Is this bad thing to try? I ask cause my 6.5g bucket I got my mash started in seems like it may be on the small side now that its going. Woke up with foam coming out of airlock. Using uncle jesse's recipe
Re: moving mash into larger container from smaller?
As long as the bigger container is cleaned and sterilized first, then there should be no problem.
_______________________________
15 gallon keg pot still
15 gallon Brew King boiler
2 35 gallon fermenters
- Truckinbutch
Relax , buddy . You are fermenting potential likker . You are not trying to incubate eggs .
To paraphrase Betty White : 'Balls are fragile , grow a vagina ; those things will take a pounding .'
- ShineonCrazyDiamond
Shine on you crazy diamond."
