Possibly noob corn mash questions
aczesz
Post by aczesz »
I have been using some grainland select rolled corn to make my mashes. For the life of me I cant get the SG above 1.030. I usually heat 6gal of water to 165*f then add it to a cooler that has a false bottom and mix in 16lbs of the corn. I stir it until the temp drops to 150*F then add 1.5lbs of 2row malted barley and let it sit for 90min stirring it occasionally then drain into a carboy. Now my question is why is my SG so low?! Am i not heating the corn enough, or should i be using more malted barely? I do an iodine test before and after and it looks like all the starches are being converted to sugars in the liquid.
For comparison, I ran a corn meal mash that was 15lbs of corn meal and 1.5lbs of barley and i got an SG of 1.060 using the same procedure as stated above. I dont want to use corn meal because it takes forever to drain and clogs my false bottom and its more expensive for 15lbs than buying a 50lb bag of rolled corn at the feed store.
I have attached a picture of the corn I am using.
Grainland Select Rolled Corn
Only drink the stuff ya make!
dieselduo
Re: Possibly noob corn mash questions
Post by dieselduo »
Looks like it should be milled more if you want better conversion
skow69
Post by skow69 »
1 Do you need to be so frugal with the malt? I would double it at least. Or supplement with some store bought enzymes.
2 Do you know for sure if your rolled corn has been gelatinized? You may need to cook it.
3 You are mashing at almost 3 lb/gal. A lower ratio would make it easier to get good conversion.
4 Have you checked the pH? You may need to correct it. I aim for 5.3 - 5.5.
5 Check your water chemistry. If it is very soft, you may need to add some calcium carbonate.
6 Finer grind makes it easier, but I know you are trying to avoid that
I hear you saying, "But it worked so good with the meal." Actually, you only got 22 ppg on that mash. I don't feel successful unless I hit 30.
On the other hand, some guys figure feed corn is so cheap that it is not worth the time and trouble to jump thru all the hoops to get good conversion. Just use more corn. I understand that point, too. In your case, at 3 lb/gal, I think you already used that option.
aczesz
Post by aczesz »
skow69 wrote:1 Do you need to be so frugal with the malt? I would double it at least. Or supplement with some store bought enzymes.
1. No I do not, I can throw more in. Is there a ratio of unmalted grain to malted grain I should be following?
2. The guy at the feed store said that it had been steam rolled. I know it did not gelatinize in my mashton since everything felt pretty liquidy.
3. I could add another gallon or two, but after that my 10gal mashton will be topped out with all the grain and water.
4. PH of my tap water is 7.13, checked it yesterday. Sounds like I need to add some acid. Best thing to add as an acid that I could pick up at a local store?
5. We have hard well water where I live and we do not use a softener.
aczesz
Post by aczesz »
dieselduo wrote:Looks like it should be milled more if you want better conversion
I have a corona mill so the next batch I will try milling it finer.
bilgriss
Post by bilgriss »
Finer milling of the corn and an appropriate cook or no-cook method of gelatinizing corn starches is important for yield.
Since you are using softened water, throw in some gypsum and epson salts with your mash. A little acid to lower the starting pH.
I suspect these are your main obstacles.
skow69
Post by skow69 »
aczesz wrote: 1. No I do not, I can throw more in. Is there a ratio of unmalted grain to malted grain I should be following?
That depends on the diastatic power of your malt. There is a bit of math involved, but 20% to 25% malt should get you in the ballpark.
Cooking corn is a PITA, but if it doesn't get hydrated it won't convert for squat.
2 lb/gal is a kind of rule of thumb. You can mash higher ratios, it's just harder.
Citric acid. In the canning supplies.
I see mashing as a complex process with many variables. You don't have to get them all perfect, but you do have to get enough of them close enough. So the better you control the ones you can, the more slack you can afford on the ones you can't.
Keep at it and stuff will start falling into place. Good luck.
HDNB
Post by HDNB »
cook ye corn for 90 minutes at 190* and above.
the Ph will drop to 6ish
use 25% of the grain bill as malt or use store bought enzymes too
use 10% ish of backset/water after the corn cookn if you want to lower the ph more, to 5.2 or so, then add the malt
the well water should be awesome. don't soften it (most softeners use sodium ion, yeast don't lurv sodium)
that corn looks cracked not steam rolled; never seen anything but barley and oats steam rolled and they look whole, flat and plump. (and require more milling). on second look, that corn don't be milled enough, steam rolled or no. gring it up.
If you cook the cracked corn for 90 minutes as described, you'll hit over 1.06 with that weight/water.
1. No I do not, I can throw more in. Is there a ratio of unmalted grain to malted grain I should be following? 25%
2. The guy at the feed store said that it had been steam rolled. I know it did not gelatinize in my mashton since everything felt pretty liquidy.starch not released
3. I could add another gallon or two, but after that my 10gal mashton will be topped out with all the grain and water.add a hint of backset after corn cook
4. PH of my tap water is 7.13, checked it yesterday. Sounds like I need to add some acid. Best thing to add as an acid that I could pick up at a local store?use backset
5. We have hard well water where I live and we do not use a softener. good
now i drink for evil.
RedwoodHillBilly
Post by RedwoodHillBilly »
HDNB wrote: that corn looks cracked not steam rolled; never seen anything but barley and oats steam rolled and they look whole, flat and plump. (and require more milling). on second look, that corn don't be milled enough, steam rolled or no. gring it up.
That looks just like the steam rolled corn that I get. I also get steam rolled barley. I do grind them to a fine powder/flour using a hammer mill, and that really helps with the conversion. This is the hammer mill that I bought https://www.amazon.com/gp/product/B010T7QGLK" onclick="window.open(this.href);return false;" rel="nofollow I ferment and distill on the grain, so the flour isn't a problem.
aczesz
Post by aczesz »
Thanks a ton for the input guys!! I ground the corn a little finer and it is right now in a big pot in the oven getting up to 190*, it has already absorbed a ton of water. I will try and take some pics and post pictures as I go today for other people like me to see.
Pikey
Post by Pikey »
aczesz wrote:Thanks a ton for the input guys!! I ground the corn a little finer and it is right now in a big pot in the oven getting up to 190*, it has already absorbed a ton of water. I will try and take some pics and post pictures as I go today for other people like me to see.
Hey - We ALL want to see ! 8)
aczesz
Post by aczesz »
You got it!!
aczesz
Post by aczesz »
Ok an update on todays mashing. Since everything got numbered in my posts I will number the steps I took.
1. Ingredients: 15lbs grainland select rolled corn, 4lbs 2row domestic malted barley, water.
2. Ground the corn semi fine, between cornmeal and the picture I posted in my first post.
3. Put the corn in a large 8gal pot and put in the oven set to 300* for 2ish hours. The starting temp of the water was around 100 and it worked its way up to 190 after stirring. Did not burn the corn at all and the pot was very easy to wash after. Stirred 3 times over the 2ish hours. I should have put more water in (put in maybe 2-3gal) as the corn soaked up literally all the water and turned into a crazy gelatin.
4. Plopped it into my sparging cooler and added a few gallons of water. It turned into a super soupy mixture and the corn and water never separated. There were some super starchy globs I broke up with the spoon while stirring. Starting temp in the cooler was about 166 and let it drop to 148 before I started the next step. Measured the PH before the next step and it was at 5.17, and my starting water ph was 7.12. I did not add any backset
5. Added the 4lbs of malted barley and sired until it was thoroughly mixed. Let it set for about 2hrs siring occasionally and the temp dropped to 140* at the end. At the end the water would separate out and sit on top of the grain. Did the iodine test and it passed with flying colors. Check the pictures for a photo.
6. Heated 5ish gal of water to 160* and added it to the top of the cooler when i opened up the valve. The flow is super slow as you can see in the photos. Next time I will probably use a grain bag
Now I just have to wait till the morning for it to finish draining into the fermenting tank and I will take the specific gravity then and post it so everybody knows how this process turned out!!
slow trickle getting lots of aeration!
draining the wash
draining the wash
Iodine test came out good!
Starch chunk while siring
Corn after being in the oven half scooped out of the pot
aczesz
Post by aczesz »
It is now the morning and 9gal of wash has filtered through the grain bed. I took the specific gravity and with heat correction it was 1.048, a little off the 1.060-1.070 that I wanted but thats ok. Yeast starter is almost done and going to be throwing that in shortly and sealing her up!! Now that iv got the process down the next run will be a lot easier. Thanks everyone for your help!
skow69
Post by skow69 »
It just gets better from here.
Enjoy!
aczesz
Post by aczesz »
I am on round 3 of this method, and I am getting the process pretty dialed. Been hitting a consistent 1.061 sg over 3 separate mash days. BeerSmith is telling me that my "Brew House" is at 88% efficiency. Getting about 10gal of wash liquid into the fermenter. The grain absorbs about 2gal of water.
Hillbilly Popstar
Post by Hillbilly Popstar »
Just my 2cents.
You should skip the sparge. Corn whiskey is traditionally fermented on the grain.
There are beta enzymes that will keep working on those star he's throughout the fermentation.
Plus sparging ground corn must be a royal PITA.
Hillbilly Popstar wrote:...You should skip the sparge...There are beta enzymes that will keep working...throughout the fermentation...Plus sparging ground corn must be a royal PITA.
Yes but, squeezing good alcohol out of a soupy yeast cake is also a PITA. Pick your poison. YMMV.
p.s.- I lauter all of my mashes too. Less mess to clean up at distillation (stripping) time.
Hillbilly Popstar
What's the difference between leaving alcohol in the post ferment corn cake and leaving fermentable sugar in the pre ferment corn cake? Either way, its a loss.
I'd imagine it takes a good bit of sparge water to get all the good stuff out of the corn, if it even lends itself to sparing well enough. Plus you don't get the benefit of having continued conversion throughout the ferment.
But you're right, squeezing grains is not a fun job and almost always results in needing a shower afterwards. Lol
aczesz
Post by aczesz »
I would ferment on grain but my current fermenter isnt big enough. As for sparging the corn, its not actually that bad, takes about 15min of adding water then 45min-1hr of letting it sit there and drain unsupervised.
MrKaos63
Post by MrKaos63 »
After reading through this I am going to try a corn mash.
Basics learned front this thread
2lb grain per gallon of mash
Grain blend needs 25% malt to release amylase
Boil corn for about 90 min till gelatinous to release starch
Check ph and iodine test
Drop temp to 148 f add malt and hold temp for 2hrs
Cool to 85 f add nutriants
Pitch yeast
I am going to try a 5gal wash
7.5 lb cracked corn
2.5 lb rye malt
1/2 yeast bomb
1/2 cup yeast
Am close to dialed in.
aczesz
Post by aczesz »
MrKaos63 wrote:After reading through this I am going to try a corn mash.
Pitch yeast
7.5 lb cracked corn
2.5 lb rye malt
1/2 yeast bomb
1/2 cup yeast
I would recommend putting the corn and water in the oven instead of on the stove and boiling it. I have tried to boil the corn on the stove before and you have to sit there and constantly stir it otherwise it will burn. The oven method is indirect heat so it will be much harder to burn. Keep it in the oven at 300*F until you start smelling corn then take it out and stir it to check on it. It should be an extra thick goop. I use 6gal of water for 15lb of corn in the pot and the corn will absorb all 6gal.
Are you sparging or fermenting on grain?
Also, I'd add to mill the cracked corn finer if you can...down to a cornmeal grind if possible. Store-bought cracked corn is coarse and will be harder to mash than a cornmeal grind.
MrKaos63
Post by MrKaos63 »
[quote="MrKaos63"]After reading through this I am going to try a corn mash.
Bake corn at 300°f till gelatinous ie extra thick goop to release starch
Pitch yeast
7.5 lb cracked corn ground to a meal texture.
2.5 lb rye malt ground?
1/2 yeast bomb
1/2 cup yeast
When baking corn... 6gallon water to 15lb of corn
I see some folks strain thier mash. Is straining Sparging?
I think I want to ferment then strain or not strain at all.
Thanx aczesz and still_stirrin
rgreen2002
Post by rgreen2002 »
RedwoodHillBilly wrote:...This is the hammer mill that I bought https://www.amazon.com/gp/product/B010T7QGLK" onclick="window.open(this.href);return false;" rel="nofollow I ferment and distill on the grain, so the flour isn't a problem.
Hey, Redwood... I've been eying that mill on Amazon for a while now. How do you like it?
HD Glossary - Open this
aczesz
Post by aczesz »
Pitch yeast
1/2 yeast bomb
1/2 cup yeast
Yea it is basically sparging. If your fermenter can handle the volume then ferment on the grain. I will have to say though if you grind the corn fine its going to be super hard to strain it. I use the rolled corn and it still takes a few hours to drain. Also my 19lbs of grain will soak up about 2gal of water that I cant get out of it. If you can get a big cheese cloth bag and put all the grain in it before you ferment so it is easier to squeeze the liquid out of it
RedwoodHillBilly
Works good for me. One thing that I like is that I can put 25# of grain in it and just wait for it to be done. It's holding up ok for now, we'll have to see how it lasts. I've only put 600# through it so far.
Hillbilly Popstar
Putting a pot of water in the oven over 212 degrees can have disastrous results.
It can flash boil and literally explode.
