New to distilling...
Hi Everyone,
thanks for accepting my application,
So here in sunny South Africa we have been in various levels of lockdown since the 27th March 2020, during which alcohol sales have been banned! so what started out as some "essential Brewing" ended up in essential distilling (Mostly due to a particularly unpalattable pineapple beer !)
access to all the nice shiny bits I've seen on the forum is limited in SA and with funds being on the low side I had to build my first potstill from bits I had lying around and a bit of help from a buddy who can weld stainless steel. THe result is this rather crude attempt... It works though and so far I have produced a quite drinkable whisky (Little low on the ABV but then it was a first attempt) a more than drinkable rum and this last weekend I produced a somewhat lightly flavoured Gin (from a sugar wash and feints from my rum). That ran 5Litres at 80% ABV before tapering
anyways I have some questions about using feints for High ABV neutral spirits but I'll address that to the correct forum, oh and the still is very much a work in progress. THis weekend should see the addition on a Gin "chamber" in that rather skinny looking column...I'll post when its done....
Re: New to distilling...
wecom to HD myself from RSA. quite a few from SA on here lately. enjoy, read lots AND if things here contradict local or tube knowledge just read more on here to understand it better.
My first flute
My press
My twins
My controller
My press
My twins
My controller
Well, good on ya’ for being “resourceful”.
But, “awe shucks”...I see a couple of dangerous features in our still:
..1st; the glass jug “thumper” is a huge NO NO. Get rid of it asap.
..2nd; the small copper tubing from the riser to and through the worm is too small. A puke can push crap into it, potentially causing a plug.
..3rd; it looks like a rubber gasket between the boiler lid and the boiler vessel. Rubber is dissolved by high temperature alcohols, so you can get leaching of toxic chemicals into your spirits.
I realize that the hobby is an intrigue, especially when your government controls retail sales. But this website promotes safety rather than the illegitimacy, hopefully to gain respect within the governing entities.
And always blow through your tubes before starting.
An insect or an insect nest nest can block it with maybe disastrous results.
Thanks for the advice guys.... will replace the thumper, although i got the idea from a couple of sites showing mason jars for the same application... guess you can't believe everything you read on the net....
As for the gasket i had cork in there but i think that was synthetic too.... how about food grade silicone? Otherwise i guess a copper ring could work too...i completely agree on the riser...i do disassemble and blow through after every run to be sure but I'm working on replacing it with 50-60mm stainless...
We live and learn....
I love the cobbled together still. Great that you made palatable rum! This is a great intro into the hobby.
But yeah get some safer materials as soon as you can.
As in real life, some people on the internet are idiots and their practices best avoided
Silicone isn't allowed here either. Keep in mind ethanol isn't food, it's a powerful solvent. Even more so when hot.
Looking forward to your future build!
Ok so almost 3 x months later and here's my new updated still minus the dangerous bits i hope.
- Twisted Brick
Love it! Where there’s a will there’s a way!
I like the way you fixed the lid on.
Did you weld tabs inside the vessel or was there a rim left on top, to fix the screws onto?
Hey Baker,
I had studs welded on the inside of the vessel. The studs were welded first then the plate seam welded to the top of the vessel. Leaves a nice smooth surface to pull the lid down onto.. still have to seal it with some flour paste which is a pain if you're doing multiple runs. I guess a Teflon seal would probably work too, just not sure of the toxicity of Teflon?
