Thanks guy for the good words
Infinitebrainspace wrote:I have a 20gal ss still but I only fill it to 15gal... electric using the biggest 110v element Home Depot had (2000w I think) need a 20Amp circuit to run it, and not less than 10 guage wire. BE SURE NOT TO HAVE ANY SOLIDS in your pot!!!!
if you do, the element will burn out fast. (this from experience btw) . Strain your beer thouroughly before putting it into the pot. It will take about 2 - 2.5 hours to heat if not insulated, and about half that time if you inslulate the crap
out of it. Mine is insulated sides and top with r12 water heater insulation. I'm using a boiler thermostat to control the temp, but unless you can find a used one, they are very expensive. I mounted thermometers at the element level,
10 gallon level, and one at the base of the column (since I am new at this, I want to see what the temps are at the different points for future reference).
You can use 2 of these elements if you run 220v (one on each leg of the 220) and still use 10 gua wire with 20A,
or you could use a 4000w 220 element, but I dont know what the wire size / amp rating would have to be.
I think the 4000w element would get too hot, and may burn your beer.
