My First Still....So I went Big!!!!
Re: My First Still....So I went Big!!!!
Postby NcHooch » Thu Apr 05, 2012 5:02 pm
If you do the math, 100 of the 1/16" holes will give you about the equivalent of a 5/8" tube. 60 of the 1/16" holes is the equivalent of a 1/2" tube....which would normally be more than enough ...but it seems the liquid on the plate really changes the equation. My guess is, 100 is minimum for a 3" column.
NChooch
3" perf-plate flute, for Carolina Boubon. Practice safe distillin and keep your hobby under your hat.
NcHooch
Postby ProChargedHarley03 » Thu Apr 05, 2012 6:08 pm
Ok Thanks NcHooch I have lots of room on the plates
I will shoot for 100! I should be getting this thing together
Next week, I just got 15 gallons of UJSSM going today!!!
Last edited by ProChargedHarley03 on Thu Apr 05, 2012 10:21 pm, edited 1 time in total.
ProChargedHarley03
Postby bentstick » Thu Apr 05, 2012 6:57 pm
Hooch, the min area of holes to suface is 8 to 12% is this right? I am asking trying to get some plates drilled for a 3 plate 4" column I will be taking to my son after I get it built.
It is what you make it
bentstick
Postby ProChargedHarley03 » Fri Apr 06, 2012 4:54 pm
Well its was time to add some holes to my plate tree!!! Thanks for the help NcHooch, so this is what i did since i had already soldered the plates
made a jig out of some old wood. It took some time but i "got her done" :crazy:
ProChargedHarley03
Postby ProChargedHarley03 » Mon Apr 09, 2012 10:27 am
So my SS fitting are starting to show up!!!! I want to get all the brass off my still!!! its not cheap, but dont want to deal with the soaking the brass :cry:
I'm going to stick with the 3/8 fitting they worked great with my still :clap: my Blichmann SS ball valves should be here this friday!!!!! I have a 15 gallon batch of
UJSSM to run this weekend :D
ProChargedHarley03
Postby Richard7 » Mon Apr 09, 2012 11:42 am
Will your construction be done this weekend?
Richard7
Postby ProChargedHarley03 » Mon Apr 09, 2012 12:28 pm
Well, stubby will be ready,"The name i gave my still after i cut it in half", but will be finishing up on the plate tree section next week!! My trap fittings will be here on thursday!! I need to order the glass, at mcmaster-carr!!!
I will do 2 or 3 Gens of UJSSM!! With Studdy, then with all the saved up heads and tails, Add the plate tree section to studdy, with the tri-clamps, and see what i can get!!! :esurprised:
I think im going to name my still "Dr Jekyll & Mr Hyde....One still,Two way different personalities!!!! :thumbup:
ProChargedHarley03
Postby ProChargedHarley03 » Mon Apr 09, 2012 6:20 pm
So, this is what i am up too!!!! need my ball valves, but they are on the way!!! :clap:
ProChargedHarley03
Postby ProChargedHarley03 » Wed Apr 11, 2012 7:04 pm
I got some work done today :clap:
ProChargedHarley03
Postby ProChargedHarley03 » Thu Apr 12, 2012 9:23 pm
I'm so close i cant stop!!!! :esurprised:
ProChargedHarley03
Postby ProChargedHarley03 » Thu Apr 12, 2012 10:07 pm
few more pix's :thumbup:
ProChargedHarley03
Postby seaguy » Fri Apr 13, 2012 5:11 am
Real nice work PCH . You're like a bulldog with a rag doll on this project :) You better make sure the mrs ain't looking for a hitman :lol:
2" x 5' Boka, 3/8" coil / 3/4" cold finger, 15gal 220v 5.5kw heater, Tincup's controller
seaguy
PreviousNext
Return to My First .....
Who is online
Users browsing this forum: Whistler and 4 guests
