My potstill consists of a Stevens's keg(still not sure of the size but it holds 50 liters with room) I have a 26" long, 2" column with a 24" 1/2 " liebeg condensor. I am using a 60,000 btu. propane burner. I have a parrot I built to measure the ABV. This still works awesome.
I took 250ml of foreshots from both runs and will use these for other things than drinking. I am still not sure exactly what to keep for hearts, heads and tails. The liquor started coming off at 60% ABV and I stopped at 30% on the first run and 40% on the second run. My problem is that it all tastes fine to me. It is easy to taste the difference between the first heads and middle cuts. You cal really smell and taste the difference in the first few containers. The tails ( if I was even into them, also tasted quite good) I never really noticed any wet cardboard tastes or smells. You can taste a difference as the alcohol seems to be diminishing. I have not started blending as of yet.
Any suggestions as to blending? I have about 12 liters or so collected. In small amounts in the beginning then 500ml to 1 liter collections. I am not thinking about redistilling what I have. it has a great taste, aroma and a fair bite.
How can you tell when the heads finish? I think they taste fine but have bite. Would this deminish when blended ? How far would you use the tails. I think I was just starting to see some oils or residue. The last jar on my first run is at 40% and its smooth.
This is a lot of fun, considering I have spent close to 200$ on my build, 40 dollars on sugar and 8 bucks on sweet feed.
any input would be appreciated.
