my first REAL BUILD..3" vm
bowhunt76
Post by bowhunt76 »
so after spending almost a year in the shadows (since my first few posts) reading i have decided after being inspired by PROCHARGEDHARLEY to build this 3"vm column
i started with the reflux condenser, 10" double wound coil in 1/" tube
soldered into the cap
after having a vision in my sleep about the vent hole i decided to make this....a diesel exhaust flapper inspired vent cap!
next was the 40" of 1 1/2"over 1/2" leibeg
my shizzle......13gal 3" vm.http://homedistiller.org/forum/download ... p?id=19748
E. CLAMPUS, VITUS....HANG THE BASTARD
bowhunt76
Re: my first REAL BUILD..3" vm
Post by bowhunt76 »
continued....
i also did the wire wrapped around the vapor tube..i used 8ga stranded wire tined and solder onto the tube on both ends with a kiss of solder every wrap the length of
wait for next page
bowhunt76
Post by bowhunt76 »
continued....
i then reassembled and soldered and polished
then i started the 48" overall length column ive got 36" below the tee and 12" over the tee.. 4' sections available thru plumbing supply.com
wait for next page
bowhunt76
Post by bowhunt76 »
continued...
i then solder the 1" take of arm with a pickled 1" ball valve, was gonna go gate valve but like the faster operation of the ball valve. At any rate i will most likely be changing this to a stainless ball valve once my pocket book gets its breath back.
this is as far as ive got and still have a week or so till my new boiler is here and ive got lots a polishing to do in the mean time so.....any thoughts would be appreciated as ive got time to make changes .....on a side note my thoughts for for packing for now will either be none or copper mesh when i wanna fiddle with the refulx.I mostly run pot mode as i usually run all grain corn mashes and have very good results with the processes ive been using. I had toyed with the idea of running slant plates but whiskey is more what im after than neutrals so i figure i can add them in later if i want. this is also what i took into consideration when determining my column size as i really wanted to keep it short enough to run flavorful whiskey but have enough height to get good reflux if and when i decide to use it. although i might 15-20 minutes of reflux on my corn batches just to raise abc% a tad.
any ways gimme your thoughts good or bad and ill get back with more copper porn when column meets boilers and is all nice n pretty.
Butterman
Post by Butterman »
Nice.
I like your 'Diesel' inspired flap on the vent cap.
I was wondering if your running it in pot still mode wont the vent cap let the vapor escape? Maybe a seal on it then you wont have to run your top condenser? Not sure how VM works in Pot mode.
Butterman
bowhunt76
Post by bowhunt76 »
Butterman wrote:Nice.
Butterman
thanks on the cap ...as far as running in pot mode i will have a needle valve in front of the reflux coil to make adjustments to allow enough cooling to keep the vapor from makin it all the way out, although if it doesnt work ill just get another 3"cap and use flour paste on er
heartcut
Post by heartcut »
Nice rig. Your diesel RV should work well even in stripping mode. Just make sure it'll hold 0.5" water column and you're good
heartcut
W. H. Auden
bowhunt76
Post by bowhunt76 »
continuing......
this cool little wire rack was getting thrown out from my work and i thought id would go perfect so
i wanted to be able to slide my camp stove in and out easily and also for the height i needed to remove the bottom shelf. so i cut the front and middle out of the shelf and left the sides and back for support of the legs
next was to cut an opening to allow the column to pass thru and originaly was gonna cut close to the size of the column for added support but the boiler size would not really allow that .would of needed to raise the middle shelf another 4 inches or so so i just opened it up enough to work the clamps and what not also had a cool wood top that sits on the shelf opened it to the same dimensions
im on my way out to finish hooking up the cooling lines and then its time for some cleaning runs........heres a close up of the boiler which is amazing thanks to the guys at hillbilly :clap:
Butterman
Post by Butterman »
That is a very pretty boiler, wow.
I really like your cart conversion and set up, looks great.
Butterman
bellybuster
Post by bellybuster »
ya wow, would love some details on the boiler.
bowhunt76
Post by bowhunt76 »
bellybuster wrote:ya wow, would love some details on the boiler.
sure whatcha wanna know?
bellybuster
haha, where'd it come from? Looks like the perfect vessel with built in adaptability
bowhunt76
Post by bowhunt76 »
got the boiler, stainless to copper adapter and all the tri clamps from hillbillystillsdotcom. its 13 gals with fitting for electric element thats blanked off, fill opening on top and drain and it built to last im tellin you. things a battleship im also using the ptfe gaskets from mcmaster carr
bowhunt76
Post by bowhunt76 »
runnin my sacrificial run as i type just now comin up to temps any last minute advice for me from the heavy hitters on runnin reflux figure nows a good time to practice ...
Azure
Post by Azure »
The flapper made me grin from ear to ear. Frikin' brilliant.
bowhunt76
Post by bowhunt76 »
so i just finished a 5 gal sac. collected bout 5 3/4l from 140 down to 25 or so .and with in an hour had the rig drained reloaded and warming also had to drain my cooling water as the 20 gal recirc i use did not hold up to running both reflux and product condensor i ended up plugging everything with flour paste about 1/2 way thru the run as i could not keep the vapor knocked down enuff to not hit my vent. even when barely running any reflux to get a decent collection rate.i only refluxed for bout 20 mins just to see what shed do. so....finished in straight up pot mode getting ready to run first actual stripping run now in straight up pot mode with a fresh load of cooling water well see how she runs.......... :thumbdown: ? :thumbup: ?
i also tried makeing changes on the heat as well but still really could get a handle on it with out totally losing my take off ....just saying
corene1
HD Distilling Goddess
Post by corene1 »
That is a gorgeous setup and very well built. It looks so complicated though I am still trying to figure out how all of it works.
bowhunt76
Post by bowhunt76 »
well thanks on the kind words corene. as far as the design of the still its supposedly one of the easier stills to run. In theory as far as i know this setup basically runs just like yours but i have the option to shut down the take off (or start with it off) and force relux back into the packed column(right now im running unpacked for stripping) or if it had plates, slanted or other wise by controlling the cooling water to the reflux condersor at the top of the column..this how ever is the part i have not yet mastered as i noted previously i had to abort any type of reflux action due to not being able to control my vapor..that being said im running another 10 gals right now and i noticed tonight when i was setting up for my run that one of the top condensor lines was sucking air so that might have been my problem last night when i wasnt able to control my reflux.if not im gonna half to get a bigger reservoir....well see im just doing stripping runs but im trying to play with the reflux so i can kinda get an idea of how to run it....im probably doing it all wrong so if anyones got any advice id love to hear it..................
Danespirit
Post by Danespirit »
That's a real nice setup! :thumbup:
Very clean..as i like it. Think you might have the perfect boiler too.
You can be proud of your rigg, it would give you some real fine liquor..... :clap:
Maybe you could add two small roles/wheels at the end where your boiler is? This way you would be able to move it around easily.
bowhunt76
Post by bowhunt76 »
Danespirit wrote:That's a real nice setup! :thumbup:
hey dane thanks for your compliments, you know one thing about having a rig this size is i no longer need to be running almost constantly so this setup gets completely torn down after running so i really have no need for the wheels but definitely a good idea...fixing to run off 10 gals tonight on a sprint run tonight so stay tuned ...gonna be a long night :esad:
Desertrat
Post by Desertrat »
Lookin' good there Bowhnt76! Let us know how she did. All that copper sure is nice.
