I had a still charge of about 15L of 10% All Bran plus 2L of striped All Bran from a previous pot still run. I chose to keep the units in Liters since most of our calcs. are in Liters. (KISS)
After my heads cut I have about 1.8L at about 92% airing now as I type. I think I did about a .3L cut for heads and fores.
The only thing that I am not 100% happy about on the performance of the still is that in 100% reflux I get a drip every few seconds maybe five seconds out of the liebig. This suggest that there is some minimal bypass of the RC. I'm not really sore that this is enough for me to even worry about rewinding my coil for. (Using a SS gas line coil)
I did play with the heat and the water some even after I thought I had it dialed in during reflux just to see the changes. I have enough power to get the column in what sounds like a flooded condition (gargling sound in top of column) still no vapor coming out of the top of the column
Anyway after playing I let the column equalize for about 15 min before pulling heads and fore at a few drops per second. At this point my temp gage was at about 169F.
When the temp gage started to move and the taste of heads started to go away I equalized again for 5 min before starting to pull harts and tails.
The hearts run was nice and smooth my temp gage rock solid at 170F , collecting in a nice thin stream at about 92%. When my temp gage started to move ever so slightly and the collection started to slow to a broken stream I knew I was into tails (tails taste came now to) also ABV fell to around 89%.
I did another 5 min equalize and collected till collection slowed again and called it a night.
All in all this was a good first run and I am pleased with the results
Any feed back is always welcome as well as any questions I can answer.
Cheers.
