My first soldering experience
. . . it went . . . . bad. And yet better than I expected!
I think its now operational but pretty ugly. I guess I could clean it up and make it all shiny again. On the other hand, purposefully aging it and distressing it is kind of tempting!
First one didgnt go so well, lots of small gaps Second plate was better Had a second crack at both, then a third. And I think the forth had it sorted haha
Re: My first soldering experience
You've not picked the easiest thing in the world to practice on
2 Main questions ; Is it leakproof ? Does it work ?
Take it form one who has learned to solder and weld the hard way - It looks fine !
Pikey wrote:You've not picked the easiest thing in the world to practice on
Bahaha, Yeah. As I was getting things ready to start I had to mini me's, one on each shoulder.
The first said:
"You know the smart thing to do here would be to take some of that scrap copper over there, and set up a little practise test. . . . "
At that point the second took over:
"Fuck that! That's no fun! She'll be right mate"
That is about as far as I have gotten with the build. So have not been able to test it with a steam only cleaning run. It does hold up to a soapy water / bubble test though.
The 4 main tips I can give.
1) Clean clean clean some more before soldering any place you want solder to stick
2) Use lots of flux. Haris stayclean works really well and easier to clean.
3) Normal non-lead plumbing solder works well for filling gaps but solder wiht some silver content will flow better into small cracks.
4) be careful on heat.. too much can cause you issues and make your flux not work well and will need to reapply.
Any place were there is a gap. you can clean the area apply flux and then heat till the solder just starts to flow. it will suck into the cracks. You might also need to apply a little more solder to finish the job.
Keep it up and good luck with the rest of your build.
B
B
Awesome thanks!!!
I did a BUNCH of reading (on this forum mostly) before giving it a crack. I guess its one of those things where you just don't really get it until you have seen it a few times. I guess it's all relative.
For example I think to start with I was actually not using enough heat. Because I was scared of "using too much heat" hahaha. Its cool though, I actually think im goign to find it fun. So I'm sure I will keep finding excuses to keep practising.
Thanks for the input man! Appreciate it!!
- der wo
Also to tease you, I found, besides practicing, youtube videos were great to learn to solder.
BAHAHAHAHAHA! Well played sir!der wo wrote:Also to tease you, I found, besides practicing, youtube videos were great to learn to solder.
But yeah makes sense. Its the kind of thing that words dont quite get across not for me anyway. I found a few videos that were good. But most were for plumbing type things. Guess the boka is a bit of a unique soldering problem.
For a very neat job of soldering boka plates, is the make the plates just about 1/16" wider that the size of the pipe.. and use 1/16" size solder and if you don't have small size solder, cut a 12" piece of regular size, flatten it some, then cut it in half.. the smaller size require less heat to work with and easier to work with.. once the plates are soldered in, grind then flush with the pipe..
Mars
Mars
– Albert Einstein
– Albert Einstein
Looks fine to me (but then you should see the quality of my soldering).
I like to think that 'unique' stills like this make spirits with more character to them
StillerBoy wrote:For a very neat job of soldering boka plates, is the make the plates just about 1/16" wider that the size of the pipe.. and use 1/16" size solder and if you don't have small size solder, cut a 12" piece of regular size, flatten it some, then cut it in half.. the smaller size require less heat to work with and easier to work with.. once the plates are soldered in, grind then flush with the pipe..
Mars
Hmmmm interesting, that is similar to what I did but I think the solder was larger. And perhaps, just being a rookie didnt help haha
Mikey-moo wrote:Looks fine to me (but then you should see the quality of my soldering).
Hahaha yeah man!
Im very serious about the aging and distressing idea. I think it could be kind of cool. Dark different colour patina, old scratches and scrapes. With new shiny copper markings on it as well. As in actually actively try to make it elegantly disheveled haha. Go all Adam Savage on it:
https://www.youtube.com/watch?v=YXzxEqd ... nel=Tested" onclick="window.open(this.href);return false;" rel="nofollow
