Hi,
I did my first sugar wash for distillation, and used a simple sugar wash recipe
12 Lbs Sugar,
4.65 ounces Yeast Nutrient
1.80 ounce Bakers Yeast
6 Gallon Water
I distilled it once with a reflux still and got 70 ABV but I have learned yesterday with my post that my gig is partly reflux there is not a reflux jacket for it only a 75 cm long condenser, and a column packed with copper mash so, I think it worked almost partly pot still and reflux, anyway as I said I only used the above recipe for the wash, and got a strange smell in the alcohol, it was definitely a bit sugary taste and some vinigar smell as well this is really hard to describe, today I redistilled it again, the smell was there did not go away and the strange thing is my ABV only went from 70 to 75 in the second run.
so a friend of mine whose doing distilling longer than me suggested that maybe something was wrong with the fermentation due to sugary taste in the distilled alcohol, also said it could be the yeast also, so what do you guys think went wrong I discard it but really wanna know why there is a smell even in the second run and why my alcohol level did went up only from 70 to 75 ?
Strange Smell in the distilled product need help
Re: Strange Smell in the distilled product need help
read everything in this thread, i think it will answer most of your questions.
http://homedistiller.org/forum/viewforum.php?f=15
now i drink for evil.
Had you done a wash from the "Tried and True" recipe section, you wouldn't be asking question for the answer to the problems you run into..artooks wrote:I did my first sugar wash for distillation, and used a simple sugar wash recipe
Plus the still be new, was it properly clean, water and vinegar run, then a sacrificial run before tasting anything..
It would be wise to slow down some, and do the proper research required, otherwise help will be slow coming..
Mars
– Albert Einstein
– Albert Einstein
+1 what they all said, with the addition of:
Did you make any cuts? Or just collect it all on 1 big jug?
