Hi,
This is my rig, I purchased it here in Turkey from a guy who builds these, he claimed this can be used both pot still and reflux, but there is not reflux jacket only column and packing so I guess this is half
reflux yesterday they mentioned it in the forum, these are 2" tube so I want to buy an reflux jacket for this rig, which one can you recommend me ? please give me links but it has to be 2" tube with a ferrule to clamp it down with a triclamp.
My Rig and 1 question
Re: My Rig and 1 question
Re: My first Distillation Need Urgent Help
Unread postby artooks » Mon Mar 13, 2017 4:02 pm
Well they are made by a person here, the rig is good but insturctions are not supplied at a great extend
Artooks.. why are asking questions about your rig, when it has already been pointed out to you what was thought of the rig in your other post..
Mars
Mars
– Albert Einstein
– Albert Einstein
Hi, I am showing detailed pictures of my rig and trying to find where I can buy a reflux
Jacket, what is wrong with that, I did not have detailed pictures in my other post.
But the thing is whenever I ask a question as a new starter, I am receiving a different reaction
I do not know certain things and really appreciate the help.
you can simply wrap a 1/4" coppertube around the pipe and stuff the column with pure copper scrubbies. won't be super efficient but i have a rig set up like that on a 2" copper pipe and it will get to 90% if you try hard. i think i used about 10' in total. (about 3 Metres)
if you buy a short extension spool for the top, you could put a reflux coil in that and make it into a CCVM system. look for dad300 posts for links to instruction for that type of build.
now i drink for evil.
- Badmotivator
Because your column has Trip-Clamp fittings, finding a reflux condenser to buy will be easy and relatively inexpensive.artooks wrote: I want to buy an reflux jacket for this rig
Search terms:
- 2" or 2-inch or 50 mm
- triclamp or tri-clamp or tri clamp or tri-clamp-compatible
- reflux condenser or dephlegmator
Hope that helps.
Trying to make it real compared to what?
Badmotivator Barrel Construction, Start to Finish
Thank you very much HDNB and Badmotivator, it helps.
+1, a very cheap upgradeHDNB wrote: if you buy a short extension spool for the top, you could put a reflux coil in that and make it into a CCVM system. look for dad300 posts for links to instruction for that type of build.
Modular 2" Pot Still
