bumps inthe road
Hoosier Shine9
bumps inthe road
Post by Hoosier Shine9 »
I got the rest of the equipment for the still.
got the controller put together, the 5500w element into the guard kit, and all the wiring ready.
I attached the 5500w to the keg. added about 5 gal of water. small leak :oops: . thought I had forgot to tighten completely. took element off tightened more (as tight as I could). Still dripping :ranting: .
off to Menards.....thought there might be a problem with element. got a 4500w, this store does not carry the 5500w :doh: .
Back home, put 4500 into guard kit, tightened by hand felt a bump, looked inside. realized I had smashed gasket out from under the flange on the element. loosened, felt the bump "undo", tightened about a 16th of am inch or so. Put onto keg...no leak :D . I assume I did the same thing to the 5500w...... :shock: :ranting:
Put 5 gal of vinegar in, so about 10 gal total volume.
Plugged in and turned on the controller heard a hum, looked into the fill port. to quote Don Ho...."tiny bubbles".... :8).
about 3/4 to 1 hour later boiler at 210. kept feeling the column to follow heat up. about 15 minutes later temp on column top starts going up it hits about 160. I hear a little "tick, pop" :cry: I see a crack in lens #3 from bottom...... :x :evil: :ranting: . I shut everything down.
After the fact I realized I had tightened the clamps too tight.
I learned a lot from this "practice run".
Called StillDragon & have 6 new lenses on the way. With 5 extra I am sure I will NEVER crack or break another one....... :lol: cheap insurance.
I am sure you have heard of "Murphy's Law" Unfortunately I live under a different law....SC's law...."Murphy was a bloody optimist".... :doh: :cry:
I have a 10 gal ferment of Bird Watchers almost ready,, just have to wit for package to arrive so I can finish cleaning run. then on to the sacrificial run.
Mikey-moo
Re: bumps inthe road
Post by Mikey-moo »
Nice write up - I feel your pain re the sight glass.
I look forward to the report on your sac run :-)
olecajun
Post by olecajun »
Thats a good posting. Keep us up to date. Postings like yours makes some of us feel like we might be right there watching and hearing all that ranting. :ebiggrin: Waiting to hear some more. Be safe.
Gator Meat ;; Its whats for dinner
I think you were very unlucky to break one of those SD Lenses.
Ive been running 4 of those lenses with SD seals/gaskets for over five years now.
Ive pulled them out and put them back in a number of times over those years and never had one break or crack. Ive done them up very tight at times and still never broken one.
Not trying to give anyone a free plug, just stating the facts.
Hoosier Shine9
I am not trying to say that the lens was bad. The fact that it broke was 100% MY FAULT!!!!
I live under SC's law....Murphy was a Bloody OPTIMIST.......lol
yakattack
Post by yakattack »
SC's law? Do tell. I'm curious now
Truckinbutch
Post by Truckinbutch »
When it comes to stilling I believe that 'Murphy' is an optimist . The most random things will screw you if you are not 100% vigilant .
This is not a casual hobby .
speedfreaksteve
Post by speedfreaksteve »
Truckinbutch wrote:When it comes to stilling I believe that 'Murphy' is an optimist . The most random things will screw you if you are not 100% vigilant .
100% true. You can't treat your still like it's a microwave. There's so many factors to can go wrong. Test your condenser before the start your run. Double check your propane before a run. Make sure your still is on solid footing and can't possibly fall over even if a dog runs into it. Etc...
_______________________________
15 gallon keg pot still
15 gallon Brew King boiler
2 35 gallon fermenters
Hoosier Shine9
yakattack wrote:SC's law? Do tell. I'm curious now
Murphys law:\
If anything can go wrong it will, at the least opportune moment.
SC's law (I have also heard it called O'Riley's law.)
Murphy was an optimist
The "SC" is due to ancestry and my last name.....
