First ag run
First ag run
Ran my first all grain stripping run last night. Had 14 gal of wash, starting og was 1.045, ended at .999-recipe was 60 percent corn, 20 percent white wheat, 20 distillers malt. Turned out really smooth, I ran wash in thumper. One thing was different from my brandy and sugar heads, the cuts were really distinct- I used pints, 1st 2 were 130 proof, then held at 120, then about 7 pints in it dropped to 80 proof, then after 3 pints at 80 dropped down to 30, then got cloudy n I stopped. Is this the norm for ag runs? The whiskey is airing now, out of 14 gal wash I got almost 2 gal. The taste is totally different from a sugar wash with corn n wheat thrown in. I see now why it's held in high regards- it's tough not to dust that fermenter with sugar. Lol but it's worth it.
semper fi
Re: First ag run
Not bad for a "one and done" run.
Typically, I would do 3 strip runs and a spirit run with the low wines from the 3 strip runs. I ferment 10 gallons at a time, so the 3 strips gives me 27-28 gallons to run. In the end, I would expect 3-1/2 to 4 gallons of cask strength.
So, it sounds like your first all grain is about "par".
Re: First ag run
I'm new to doing all grain, n new to doin multiple distillations, when dad made likker he jus ran it one time, n it was so rough u could strip paint off titanic with it, If I understood what I been reading, then I do several strip runs til I have enough to run for a spirit run. So basically ur saying after 3 10 gal strip runs u have 3.5-4 gal of distillate for ur final spirit run. Is that correct? Last night I ran mine a little faster n hotter than normally would, I read on here it's ok to do that for strip run. N I also noticed more fusils coming out too. Dunno if that's y, even tho it was strip run I separated cuts jus to see wat was goin on. I have a 15 gal pot so it's gonna take me several strip runs to get enough for spirit run.
semper fi
Re: First ag run
No. That is the product from the spirit run. Each strip run produces 3 gallons of low wines such that the spirit run charge is 9 gallons.Bavis54 wrote:...after 3 10 gal strip runs u have 3.5-4 gal of distillate for ur final spirit run. Is that correct?
That is to be expected. If you read kiwistiller's guide to cuts, you'll see how the constituents come over throughout the run. Running faster/more power causes more smearing throughout as well. So I would expect that you'd notice the tails more throughout the run.Bavis54 wrote:Last night I ran mine a little faster n hotter than normally would, I read on here it's ok to do that for strip run. N I also noticed more fusils coming out too. Dunno if that's y, even tho it was strip run I separated cuts jus to see wat was goin on. I have a 15 gal pot so it's gonna take me several strip runs to get enough for spirit run.
But, it IS a stripping run. So you don't need to make cuts on it. Educational...sure. But no need for more questions why it tastes crappy. It's a strip...meaning, there's another pass planned.
- Oldvine Zin
Re: First ag run
You are doing well and have come a long way Bavis, Sorry that I was harsh on you early on
Keep up the good work and you can always do a sugarhead from your spent grains - reuse and always better than an all sugar wash.
OVZ
OVZ
Re: First ag run
Hey thank you OVZ- no need for apology bc to be quite truthful u were correct, if I look hard n really research here at some time or other someone has already talked about or asked wat I'm stuck on. I am ashamed of the way I got all pissy n for that I owe u an apology. I am very sorry for cursing u n being so rude. I cannot think of a single time I asked for help or advice here that someone did not help me with great accuracy. I enjoy this stuff so much that when it's midnight n I'm bent over a mash pot wondering why got no conversion or wat went wrong I panic instead of stepping back n searching here. N it's easier to ask instead of doin a bit of finger walking or research. But I am trying to get better. I very much enjoy learning and conversing with the ppl on here.
semper fi
