This morning, I got a pleasant surprise. My Bayou classic burner and accessories arrived 2 days ahead of schedule. Being as I have the full use of this beautiful September day, I decided to run my 5 gallon sugar wash for my cleaning run. I'm running an 8 gallon SS pot still, no thumper from Brewhause supply. Last night I used the electric band to run full steam solution of vinegar and water. I had appx 5.5 gallons of wash made with 12# table sugar and 5 gallons of water. I used Liquor Quick turbo yeast for fermentation. Quite a spectacle it was. I cleared it yesterday this morning it was very clear. My OG was 1.068 and FG was .990, about a 10% ABV potential. I racked it into the boiler and set up out back on my patio. I have photos of my setup but do not know how to post them here. The bayou burner runs great, has an adjustment valve for gas flow as well as adjustable air aperture. You can get a good 60KBTU flame and easily adjust it down to a simmer. For cooling, I used a submersible pump and recirculated ice water in a 10 gal HD beverage cooler. About 15-20 minutes it was up to speed, and a trickle started. I was impressed how quickly the stream could be reduced or increased by adjusting the flame. Kind of like a throttle. I got the first 250ml or so, smelled just like nail polish remover. I got rid of that and proceeded to collect about a gallon in 2 half gallon jars 75 and 60 ABV respectively. This distillate smelled like cotton candy and was crystal clear. I wasn't concerned about cuts since I have no intention of consuming this. When I do a whiskey run, the final spirit run will be collected in pint mason jars. After things cooled down, I combined the distillate and diluted down to just under 40%. I got rid of the remaining wash and rinsed out the boiler and re-ran. I ended up with about 3/4 gallon that reads 85% ABV. It still had a candy type smell but not as sweet smelling...more like a vodka. I diluted a tbs or so and tasted it...it tasted kind of sweet as well. There has to be something to this because I also attracted every bee, wasp, and hornet within a 5 mile radius. I do have some observations:
The flow is directly proportionate to applied heat. This is why an element or a band or a hotplate without a power controller wouldn't be very good.
The distillate that was collected was about 100-120f. I thought it came out cooler than that. 5# of ice and a filled 10 gallon cooler, the cooling water was warm at the end of the stripping run. I'd say about 90f. Maybe it is better to run direct off the hose fitting instead of re-circulation. This is a steady supply of cool water. I imagine if the cooling water becomes too warm, it won't be effective and then your getting vapor out of your spout. Not good.
All and all it was a fun experience, I used about 1/3 of a 20# propane bottle, not too bad. I got to see what is taking place during distillation. I look forward to making something that tastes good.
I want to move onto UJSSM as listed here. My intent is to strip 5 gallon batches throwing out the fore shots but saving everything else until I have a few gallons for a spirit run, rather than strip, spirit run each time. Is this a good idea?
I broke my Distilling Cherry today.
When I was a boy, I prayed for a bicycle. I soon learned G~d doesn't work like this so I stole a bike and prayed for forgiveness.
Re: I broke my Distilling Cherry today.
Sounds like a plan.
Congrats
Congrats
Welcome to the pack!
As long as your outlet is not hotter than 100 dgr F, I would not worry.
And about the water: a lot of us try to recirculate the cooling water. I do not, but it is a pain to waste clean drinking water. So I use my air cooled spiral as much as possible.
A friend suggested I could fill a bath with the cooling water of a run, or do the dishes.
This was your sacrificial cleaning run? It should not be consumed. And rerunning it (after diluting to 40%) doesn't make it consumable. It's still sacrificial. Dump it! Your bowels will thank you.Chixter wrote:...Last night I used the electric band to run full steam solution of vinegar and water....(then a) wash made with 12# table sugar and 5 gallons of water...Liquor Quick turbo yeast...cleared it yesterday...
this morning...(I) racked it into the boiler and set up out back on my patio....I wasn't concerned about cuts since I have no intention of consuming this....
I ended up with about 3/4 gallon that reads 85% ABV....I diluted a tbs or so and tasted it...it tasted kind of sweet as well.
I save my cleaning run products, invariably I will make changes and need to do another cleaning run. But yes, it is sacrificial, never potable.
Welcome to the club! And yes, several strip runs feeding a big UJ spirit run is a fine plan.
- Truckinbutch
Good protocol , good results , good future plans .
In other words , congratulations ; you are fucked ! Welcome to the club .
took the words right outta my mouth +1Truckinbutch wrote:Good protocol , good results , good future plans .
Love it when a new shows up and does his research
Swedish Pride wrote:
Nice write up!
Congrats
Congrats
