First screw-up
Posted: Tue Nov 14, 2017 3:42 am
Yes, I'm a newbie.
First, two batches went well.
My third sugar wash mixed 8lbs sugar a cup of molasses, added a tsp yeast nutrient and a package of yeast. As we were going on vacation for a week I thought a perfect time to run a batch as when we got back it should be fine. No, I did not take the gravity before pitching the yeast. I checked on it right before we left and it was bubbling along fine, got back Wednesday and I was getting a consistent bubble every ten seconds or so. Saturday it had almost stopped, siphoned into the pot put the lid on and the Boka and started the heat. After a 30-minute reflux took the first 250ml and tossed. I was getting 90% into the parrot and then the column temp started to climb and the % dropped. after getting only a pint. I tried everything went back to full reflux to try to get the column down turned off the heat etc. Then I had a realization maybe the fermentation was not done. I let everything cool down put the wort back into the carboy and went to bed. Tested it in the morning and sure enough, the gravity was still showing 20% potential alcohol. I added more yeast nutrient and pitched another packet of yeast last evening, unfortunately, nothing this morning. The basement is about 68-72 degrees. I'm thinking it was too cold for the little yeasties to do their thing. any other thoughts on how to fix.
