Oxbo Rene wrote:OK, lets test this, (cause I can't see any "location data" from using the website)....
Here's a picture, tell me where it was taken ..............
You wont see any location data with this picture - the photograph was taken with an OLYMPUS SZ-10 camera, this type of camera does not have GPS capabilities.
The Meta Data file contains lots of information in this "test".
Here's the full data:
EXIF — this group of metadata is encoded in 13,906 bytes (13.6k)
Exif Image Size 3,264 × 2,448
Image Description OLYMPUS DIGITAL CAMERA
Make OLYMPUS IMAGING CORP.
Camera Model Name SZ-10
Orientation Horizontal (normal)
Software Version 1.0
Modify Date 2011:12:31 12:43:54
5 months, 28 days, 21 hours, 11 minutes, 10 seconds ago
Y Cb Cr Positioning Co-sited
Exposure Time 1/250
F Number 9.30
Exposure Program Creative (Slow speed)
ISO 80
Exif Version 0221
Date/Time Original 2011:12:31 12:43:54
Create Date 2011:12:31 12:43:54
Components Configuration Y, Cb, Cr, -
Compressed Bits Per Pixel 2
Exposure Compensation 0
Max Aperture Value 3.1
Metering Mode Multi-segment
Light Source Unknown
Flash Off, Did not fire
Focal Length 5.0 mm
Exposure Mode Auto
Resolution 72 pixels/inch
Maker Note Olympus 2 (4,698 bytes binary data)
User Comment
Flashpix Version 0100
Color Space sRGB
Interoperability Index R98 - DCF basic file (sRGB)
Interoperability Version 0100
File Source Digital Camera
Scene Type Directly photographed
Custom Rendered Normal
White Balance Auto
Digital Zoom Ratio 0
Focal Length In 35mm Format 28 mm
Scene Capture Type Standard
Gain Control Low gain up
Contrast Normal
Saturation Normal
Sharpness Normal
Offset Schema 0
Print Image Matching (690 bytes binary data)
Compression JPEG (old-style)
Thumbnail Length 7,436
MakerNotes
Special Mode Normal, Sequence: 0, Panorama: (none)
Camera ID OLYMPUS DIGITAL CAMERA
Equipment Version 0100
Camera Type 2 SZ-10
Focal Plane Diagonal 7.714 mm
Body Firmware Version 81
Camera Settings Version 0100
Preview Image Valid Yes
Preview Image Start 1,720,549
Preview Image Length 57,747
Exposure Mode Program
Macro Mode Off
Flash Mode Off
White Balance 2 Auto
White Balance Bracket 0 0
Scene Mode Intelligent Auto
Scene Mode Auto
Magic Filter Off; 1280; 0; 0
Drive Mode Single Shot
Panorama Mode Off
Image Processing Version 0112
Olympus Image Processing 0x0800 0 0 0 0 0 0 0 0 0
Distortion Correction 2 On
Olympus Image Processing 0x1115 3 3
Olympus Image Processing 0x1116 900 900
Faces Detected 0 0 0
Face Detect Area (383 bytes binary data)
Max Faces 16 16 16
Face Detect Frame Size 0 0 0 0 0 0
Olympus Image Processing 0x1204 1 0
Olympus Image Processing 0x1205 2
Olympus Image Processing 0x1206 1 0 0 200 0 2 90 0 200 0
Olympus 0x0107 29705 0
Quality SQ (Low)
Macro Off
Black And White Mode Off
Digital Zoom 1.0
Camera Type SZ-10
Resolution 1
Olympus 0x020a 0 0
Olympus 0x0225 03
Pre Capture Frames 0
White Board 0
One Touch WB Off
White Balance Bias 0
Olympus 0x0306 0
Olympus 0x0400 1
Olympus 0x0401 2
Olympus 0x0402 16,797,705
Serial Number 000JEH240640
Olympus 0x0406 1
Olympus 0x0407 2
Data Dump (3,316 bytes binary data)
ExifTool
Warning [minor] Error reading PreviewImage from file
PrintIM
PrintIM Version 0300
Print IM 0x0001 0x00140014
Print IM 0x0002 0x00000001
Print IM 0x0003 0x000000ee
Print IM 0x0007 0x00000000
Print IM 0x0008 0x00000000
Print IM 0x0009 0x00000000
Print IM 0x000a 0x00000000
Print IM 0x000b 0x00000136
Print IM 0x000c 0x00000000
Print IM 0x000d 0x00000000
Print IM 0x000e 0x0000014e
Print IM 0x0010 0x0000015e
Print IM 0x0020 0x00000252
Print IM 0x0100 0x00000003
Print IM 0x0101 0x000000ff
Print IM 0x0102 0x00000083
Print IM 0x0103 0x00000083
Print IM 0x0104 0x00000083
Print IM 0x0105 0x00000083
Print IM 0x0106 0x00000083
Print IM 0x0107 0x00808080
Print IM 0x0110 0x00000080
Print IM 0x0200 0x00000000
Print IM 0x0207 0x00000000
Print IM 0x0208 0x00000000
Print IM 0x0209 0x00000000
Print IM 0x020a 0x00000000
Print IM 0x020b 0x00000276
Print IM 0x020d 0x00000000
Print IM 0x0220 0x0000028e
Print IM 0x0300 0x00000003
Print IM 0x0301 0x000000ff
Print IM 0x0302 0x00000083
Print IM 0x0303 0x00000083
Print IM 0x0306 0x00000083
Print IM 0x0310 0x00000080
Print IM 0x0400 0x00000000
JFIF
JFIF Version 1.01
Resolution 96 pixels/inch
File — basic information derived from the file.
File Type JPEG
MIME Type image/jpeg
Exif Byte Order Big-endian (Motorola, MM)
Encoding Process Baseline DCT, Huffman coding
Bits Per Sample 8
Color Components 3
File Size 70 kB
Image Size 640 × 480
Y Cb Cr Sub Sampling YCbCr4:2:0 (2 2)
Composite
This block of data is computed based upon other items. Some of it may be wildly incorrect, especially if the image has been resized.
Aperture 9.30
Shutter Speed 1/250
Thumbnail Image (7,436 bytes binary data)
Light Value 14.7
Scale Factor To 35 mm Equivalent 5.6
Circle Of Confusion 0.005 mm
Field Of View 65.5 deg
Focal Length 5.0 mm (35 mm equivalent: 28.0 mm)
Hyperfocal Distance 0.50 m
End of meta data
If it had been taken with a GPS camera or phone and the Geotagging facility was switched on, I would have neen able to provide a map as well.
Try google images and search for "geotagged pictures"
http://www.google.co.uk/search?num=10&hl=en&site=imghp&tbm=isch&source=hp&q=geotagged+pictures&oq=geotagged+pictures&gs_l=img.12..0i24.2812.7875.0.10250.18.18.0.0.0.0.203.1390.16j1j1.18.0.eiatsh..0.0.c-Ne71wzh8c&biw=1289&bih=432&sei=3tPtT43TKuea1AWu5MXgDQ
