1 PTFE gasket I cannot find for safety
artooks
Post by artooks »
Hi Guys,
I have changed all the 2" EPDM gaskets in my rig that is fine, also I changed the boiler EPDM thick gasket to a thin PTFE O-ring 8-1/2" the only one that I cannot find to buy is the one which goes on the condenser, below I am adding the pictures of the gasket itself, and some other pictures to show the condenser link, so that maybe some of you could recongize it, I tried measuring it and looking at some online vendors, but could not find a match I think it could be 3/4" gasket but the numbers does not match up.
So the OD of this EPDM gasket is: 1.378"
the ID of this EPDM gasket is: 0.67"
I converted them from cm to inches so I did not round them up, but as I said I find all my other gaskets but with this one no luck at all, so what size PTFE gasket will be suitable for this part. ?
Condenser link 2
Condenser link 2
Condenser link 1
Condenser link 1
Gasket Drawing
Gasket Drawing
Re: 1 PTFE gasket I cannot find for safety
I can't be bothered converting it back to metric so that I know what you're talking about.
How much of that gasket is really needed? You might be able to get away with a gasket matching the ID or OD.
jb-texshine
Post by jb-texshine »
Wrap the hell out of both pieces ,separately,with PTFE tape. Put them in place and wrap more over the two together ,then clamp em together. That's how I do my keg neck and riser ferrule.
Deo Vendice
artooks
Post by artooks »
Hi, Jb-texshine, this is what I did at the moment, but I really want to buy the PTFE gasket dedicated for this ferrule.
Swedish Pride
Post by Swedish Pride »
if it's a normal ferrule it's easy.
Just measure the pipe, if the pipe is 3/4 get a 3/4 gasket, it's does not mean the gasket is 3/4, it means the gasket is to suit a 3/4 ferrule.
or get a few ferrules of different size, they cost fuckall.
or get a PTFE sheet, they cost fuck all too, and cut it out to size
or make your own gasket, might be a bit of a pain in the backside with such a small gasket, but it's doable, look up everlasting gasket
Don't be a dick
HDNB
Post by HDNB »
looks like a 3/4 tri clamp. SD sells them
now i drink for evil.
joeymac
Post by joeymac »
Sanitary fittings have a round profile Oring groove in them as well as the flanged gaskets. Perhaps you can get away with using a traditional oring of the appropriate size seated in that round groove. Orings come in a few acceptable materials for our high temperature solvent use. You'll have to look up the size charts from an online retailer to fit your need.
> Solid PTFE/Teflon orings
> PFA Encapsulated orings
> Teflon FEP Encapsulated orings
(FEP and PFA are derivatives of Teflon PTFE and have identical chemical resistance with only slightly lower processing temps)
ShineRunner
Post by ShineRunner »
HDNB wrote:looks like a 3/4 tri clamp. SD sells them
I just measured my 3/4" triclamp gaskets and measurements are:
ID: .84" or 27/32
OD: 2"
Not a 3/4" triclamp. Hope that helps.
SR
frunobulax
Post by frunobulax »
Not sure what size you need, but HERE are a few
HDNB
Post by HDNB »
ID: .84" or 27/32
OD: 2"
SR
i'm not sure what you measured for those numbers, here's what i got:
The ptfe on on the left is 7/8" (23mm) OD x 9/16 (15mm)ID available at glacier tanks.
the silicone on right is 1" (25mm) OD X 9/16 (15mm) ID available at still dragon.
both are considered 3/4" tri clamp gaskets, but i'll tell you the ptfe ones are a bitch to do up the clamp with. and the silicone ones, while used all over commercially on vapour path connections...is not an HD approved material.
ShineRunner
I guess I was wrong on mine.. I was referring to this:
https://www.amazon.com/Sanitary-Ferrule ... th=1&psc=1" onclick="window.open(this.href);return false;" rel="nofollow
The 25mm/1" OD triclamp fits over 3/4" tubing. That's what threw me off. I knew they made smaller clamps, but didn't take the time to clarify what I was measuring.
Sorry for the confusion, OP.
SR
